Hello,
I am trying to split the values contained in one field table into separate rows. For example, an entry in the field 'Numbers' would contain [12, 14, 18] and I'm trying to split it up so that 12, 14 and 18 are each their own entry in their own rows while maintaining the rest of the data. I am also trying to do this in model builder; I don't know how to use ArcPy or whatever the solution is in Model Builder so if that could be explained as well that would be much appreciated.
If more information is required I will be sure to answer tomorrow morning.
Thanks
