How do I only select certain points in a defined area and collect their data?
720
12-17-2019 04:00 PM
Nathaniel_Williams
I am tracking Geospatial responses to surveys via Survey123 from Homeless outreach workers and want to pull the data on one particular hotspot where outreach workers are engaged with individuals experiencing homelessness but I can't (on ARCGIS online or ARCGIS pro) figure out a way to filter based on a me selecting a cluster or manually highlighting the group of points by using ctrl and dragging the cursor over the area of interest.  I want to be able to present the data collected from the selected points in a spreadsheet.  To case conference on the individuals in this selected area.  Is there another method to do this?        Thank you,
by Anonymous User
Not applicable
Hi Nathaniel Williams‌,
I think what you're looking for can be accomplished with a hosted feature layer view. See "Define an area of interest" at the bottom of this doc page: Set hosted feature layer view definition—ArcGIS Online Help | Documentation
Hope this helps,
-Peter
