How do I get more decimal places to show up in the lat/long fields in the hosted feature class layer attribute table?
1040
8
07-20-2017 02:02 PM
SiranErysian2
If I double click on the cell containg the values, I can see more decimal places carried out. Is there a setting?
KenBuja
Click on the Visualization tab of the service and click the Configure Pop-up button. In the Pop-up Contents section, click Configure Attributes, then click on the field. Select the number of decimal places you want to show.
Click OK on that dialog box, OK on the panel, and Save Layer.
KenBuja
SiranErysian2
Perfect! It worked. I love this, I don't have to bug ESRI for a simple question. Thanks so much!!
SiranErysian2
OH wait! It didn't appear on the web map. I refreshed the page. Isn't the feature layer and web map supposed to be linked?
SiranErysian2
Got it thanks!
Siran D. Erysian, M.A., GISP,
Research Analyst II – GIS
Department of Water Resources
3374 E. Shields Ave, Rm. A-1, Fresno, CA 93726 (559) 230-3312
Siran.Erysian@water.ca.gov
SiranErysian2
Thanks I figure it out, I did the same to the feature layer in the web map and it took.
KenBuja
Don't forget to mark the question as answered.
RebeccaStrauch__GISP
Siran.Erysian@DWR  I changed the correct answer to Ken's response since that will be more helpful for others in the future.
KyleW
Any way you know to do this to a custom attribute display?
