How can I get a list of every variable available for use with the /Enrich endpoint?
517
08-19-2025 11:07 AM
mfcallahan
Question in the title. I've been searching high and low, and I cannot find a comprehensive list of all variables available to use with the /Enrich endpoint. I don't want to manually search for variables in the variable finder tool. I want a complete list or every variable that can be used to enrich an area.
CodyPatterson
MVP Regular Contributor
mfcallahan
Yes, but this does not contain the information I am looking for. Next to the description for parameter "analysisVaraibles" is this:
For more information about variables in data collections, visit the Esri Demographics site. Each data collection has a PDF file describing variables and their names.
However, the link to "Esri Demographics site" is broken. I also don't want to use the EnrichLayer/submitJob endpoint. I am using the /Enrich endpoint - I want to know all the possible variables that are supported when making a request to this endpoint.
AmandaRing
Thanks for reporting the broken link in the documentation - we will work on getting that updated.
Here's a tutorial on finding analysis variables to use for your data. It directs you to use this  Analysis Variable Finder tool.
If you're interested in using a full data collection, you can also use the Data Collection Finder.
It's possible to get a full list of variables in JSON format as using this request
Let me know if these aren't the resources you're looking for and I'll do my best to help guide you to others instead.
Amanda
Product Engineer - Web Analysis
