how can I download survey 123 data with an attachment field and upload it to sql server?
1018
12-21-2017 03:15 PM
RonBoyer
We have created a survey 123 survey that captures a signature.  The signature is stored as a .jpg attachment. However, it doesn't show up when trying to download all the survey data to a sql database. Does anyone have a solution?
CarmelConnolly
Hi Ron,
What method are you using to download the Survey123 feature service? Are you working with ArcGIS Online or ArcGIS Enterprise?
Carmel
ThomasColson
MVP Frequent Contributor
Are you using this method? https://community.esri.com/groups/survey123/blog/2016/12/14/migrating-data-from-the-survey-feature-s...
FYI, ESRI tech support will not support the above method (despite ESRI publishing it).
