How can I add a zipped shapefile with more that 60.000 feacher?
2261
05-15-2012 01:12 AM
admedahmeds
Hello everybody,
How can I add to my map  a zipped shapefile data  with more that 60.000 feacher?
Thank you very much.
Ahmed.
admedahmeds
I would like to add also that I have added those data to My Content_as shapefile_. But what is the next step to add those shapefile to my map?
Thank you once again.
DennisJarrard
Shapefiles uploaded to ArcGIS Online or ArcGIS Explorer must not have more than 1,000 features. This is a documented limitation.
About shapefiles
http://help.arcgis.com/en/arcgisonline/help/index.html#//010q000000m2000000
Problem:  Receiving errors when uploading a shapefile to ArcGIS Online, ArcGIS Explorer Online, Business Analyst Online, or Community Analyst
http://support.esri.com/en/knowledgebase/techarticles/detail/40010
MikeMinami
Esri Notable Contributor
This amount of data is too large to upload and display in its native format. Instead, you need to create a service from your data. Currently, you can use ArcGIS Server to do so. In the near future, you'll be able to purchase a subscription to ArcGIS Online that will allow you to create services hosted in ArcGIS Online. Look here for more information. http://www.esri.com/software/arcgis/arcgisonline/index.html
Mike
admedahmeds
Djarrard & Mike,
Thank you very much for the very fast response.
In ArcMap, I merge the 60.000 feature to (1) single feature, so I was able to add the same data the ArcGIS online map , "at least like a background" that's fine with me.
Thank once again.
Ahmed.
