Hidden Styles
947
04-16-2021 06:49 AM
SLouq
by MVP Regular Contributor
I have what should be a pretty simple question that I can't seem to figure out.
I have a feature service in a map on ArcGIS Online which I use to store points collected in the field. I used it 3 days ago and all the points collected were showing on my map. But now the points/styles are not showing or are hidden. What setting in ArcGIS Online controls how styles are displayed? I should know this but can't seem to find the setting.
I included an attachment showing what I mean.
JayantaPoddar
MVP Esteemed Contributor
You could control the style using the change style icon.
Also check
1. If the values are available in the field used for symbology.
2. If the layer is published/republished from ArcGIS Pro/ArcMap, please ensure no transparency was used before publishing.
Think Location
JayantaPoddar
Also check
Think Location
SLouq
Thanks for the reply Jayanta!
I figured out what was wrong right after I made my post. I had changed the values for my point feature to a value that wasn't in my list of domains I had set up for the map.
Thanks
