Getting Error "There was an error while adding this item"
9278
6
06-22-2022 02:45 PM
Jdstarr331
I am getting an error "There was an error while adding this item" while trying to create a hosted data layer. I referred  to  this article   that refers to this exact error, however I have an organizational account and I am the administrator for my organization, so neither solution works.
I have tried to publish a zipped geodatabase and a zipped shapefile, I have also tried publishing a webmap through Pro, but nothing seems to work. It publishes the service definition, but not the layer.
I have plenty of credits too, so I'm not sure if I am missing a setting somewhere. I am more used to Portal over AGOL.
Laura_B
Hey @Jdstarr331, I tried publishing one and was able to do so with no errors.
  • Are you able to add/publish any other shapefiles/ file geodatabases to ArcGIS Online?
  • Are you seeing any error messages on the browser console?
  • In case you haven't tried this already, you could also try running the Check Geometry tool from ArcGIS Pro.
Jdstarr331
Nope I am not able to publish either one. if I publish via ArcPro, it publishes the service definition, but no actual layer. If I add a ZIP file of either a shape file or gdb by uploading it, it also only publishes the service definition, but no layer. If I try and create a brand new one, I still get the error. I have tried in Chrome and Edge, no dice. I havent tried the tool in ArcPro, but even when I create a brand new layer, I still get the error. The only way I was able to get data to the map on AGOL was convert it to a KMZ, then upload it. But then It is not hosted and I cannot make any changes or editing.
I have a feeling its a setting somewhere but I cannot find it anywhere
Laura_B
Thanks for providing some more context, @Jdstarr331 . That's odd. If the data checks out after running the tool, are you able to create a feature layer using a template?
To be clear:
  • As an admin, have you ever been able to publish hosted content to your organization?
Jdstarr331
I literally just got the site set up a week or so ago, so no I have never published a hosted layer to my organization mage. The error message that i am getting in the browser is the one that is in the picture in my original post. When I try and publish via ArcPro, I get an error with an option to see the log file. When looking at the log file, it says there is a service definition created, but then failed when trying to create the layer
Laura_B
Oh, okay. If you've tried clearing your browser cache and all that fun stuff, it may be helpful to contact Support Services to have them investigate and take a closer look at what's going on.
ŁukaszWarzocha
I think I have a similar problem to yours. We're trying to resolve it with SupportServices, it take little more time than we expect.
When I try to add some layers to AGOL , portal returns error "There was an error while adding this item".
Thank You for cue, with kmz/kml layers, it's  always some alternatvie solution but not useful for longer time.
If You could prompt me how You remedy this problem I would be grateful.
In this way, or mayby to my email: [email protected]
