Generation of tiles caching layers in incorrect order
3406
08-28-2015 08:00 AM
JamesFrank
Hello all,
I don't know if this is an issue with AGOL, ArcGIS Pro, or me so I tagged this as AGOL.
Anyway, using ArcGIS Pro, I have shared 3 layers (2 poly and one point) by selecting the Web-Layer/Publish-Weblayer on the Share ribbon.  Unfortunately, the point layer is not visible in the tiles but does show in the legend when the WTL is added to a map.  In Pro, the layers are listed correctly in the Contents pane Drawing Order and are ordered correctly in the Share dialog Contents tab.
Pro version 1.1.0 with no updates needed
Data loaded in a file gdb on my local drive
Tiles are generating for City to States zoom levels using AGOL/ Bing / Google Tiling Schema.  Pro Scale Properties set to default instead of the AGOL scale values.
Set to Build cache automatically
I've also tried publishing a map from Pro and setting the three layers to be Tiled but have the same results.
Am I missing something?  I'm not very experience with Esri tools for caching so any help would be appreciated.
Thanks  much,
Jim
JamesFrank
Update:  I contacted tech support and after some testing found that the 3D symbol I used was causing the issue so is a bug.  The 3D symbol does not seem to affect the feature layer creation process as I was able to create a feature layer with a 3D symbol.  In tile generation however, the 3D symbol is placed below the polygons.  It is not a major issue for this situation but is worth noting.  -Jim
JamesFrank
