Garmin trackers
1633
04-10-2022 04:52 AM
DavidStegmann
Is there a way to display a map with the trackin information of a daily activity such as from Garmin Connect collected by a Garmin watch or InReach device?
RussRoberts
Esri Notable Contributor
Yup you will have to export from Garmin Connect (CSV or GPX) and upload those to Online. Currently Map Viewer Classic supports GPX and its planned for Map Viewer at a later release in ArcGIS Online. https://doc.arcgis.com/en/arcgis-online/reference/csv-gpx.htm
OwenGeo
Hi David -- Yes, I believe there are ways to do that, but this is a better question for the ArcGIS Online space. I'll transfer your question there and I believe you'll get a better response. Once you bring your data into a web map, then you can use that in a StoryMap.
Owen Evans
RussRoberts
