Hi Carmella,You may be running into a recent bug here. Could you try republishing your hosted feature service from ArcGIS Desktop, but disable "Sync" as an allowable operation in the Feature Access capabilities window and see if edits can be registered then? Thanks,Thomas
Carmie,Could you try disabling Sync on the published service's "Item Description" page then? I apologize for misleading you, as the "Sync" option appears from version 10.2 onwards. The other operations in your screenshot can be left on.Thanks,Thomas
Hi,I am using Desktop 10.1 and ESRI hosted feature services. I am having trouble pushing edits from a local copy of a feature service in ArcMap back to the feature service.My feature service layers without coded domains perform fine, it is the layers with coded domains that are an issue. I notice that these coded domain layers will take attribute table updates, but not geometry updates to existing features, and I cannot add new features.Is this a bug?Mark
I discovered that the problem is not with coded domains but the editor tracking being enabled. When preparing the feature class for the initial publishing, I had "enabled editor tracking" in ArcCatalog, and this created problems when trying to sync ArcMap local edits to the feature service. I rebuilt everything and ensured that I was not tracking edits, and everything seems to work fine now.Mark
