Forms conditions not showing on Map Viewer
1811
5
03-28-2022 06:28 AM
CorryneVincent
I created a form a month ago on Map Viewer that we use in Field Maps. Many fields have visibily conditions, it's easier to answer the form that way as some fields are required only in some cases.
But since the new update last week (march 2022), these conditions aren't working on Map Viewer, so we can see ALL fields while we should see just some of them. It's really frustrating as it's really not usefull to see all of them. Perhaps, on Field Maps it's working fine. But we use Map Viewer while working in the office environnement, so we absolutely need this to be fixed on Map Viewer!
Thank you,
CorryneVincent
Seems like this morning this problem has been fixed. My old conditionnal form is working again on Map Viewer!
CorryneVincent
Map viewer is no more respecting "required" field either. So we can edit attributes without filling required fields. That's problematic !
JessicaWay1
We are having the same issues. Forms that were using conditional formatting are now missing the formatting. We are having to go through and redo the formatting for all of the forms we just created.
CorryneVincent
Hello Jessica,
For me it's not even working to redo the formatting for all of the forms... The conditional formatting doesn't work for any fields in Map Viewer, even on new hosted features layers.
JessicaWay1
We are not having that issue as long as we don't use map viewer classic. We are using Portal 10.9
CorryneVincent
