Formatting cell values of a table added with table widget to dashboard
340
02-28-2024 09:38 AM
ellipsol
New Contributor III
I added a table widget and connected it with a table in a dashboard. I want to format select cell values. I'm think I could manage this with Arcade, similar to what's below. Is there a way to handle this table formatting in a dashboard?
var bld = Concatenate('<strong>'+$feature.LT2_Difference+'</strong>')
# Format where values are less than or equal to -1
var val = When($feature.LT2_Difference <= -1, bld, $feature.LT2_Difference);
return{
LT2_Difference: {
      displayText : val,
      textColor: '',
      backgroundColor: '#e0e0e0',
      textAlign: 'left',
      iconName: '',
      iconAlign: '',
      iconColor: '',
      iconOutlineColor: ''
2 Solutions
JenniferAcunto
You can find the Advanced Formatting for tables under the Values tab. Each column will have its own section of the return statement.
- Jen
ellipsol
New Contributor III
Thank you, I misspoke and realize I was trying in Experience Builder, not a Dashboard. I got a minimum working example with your response, in a Dashboard.
var bgcolor = When($datapoint.diffVal <= -1, '#CC0000', '')
var tcolor = When($datapoint.diffVal <= -1, '#111', '')
return
return {
  cells: {
    LT2_Difference: {
      displayText : $datapoint.diffVal,
      textColor: tcolor,
      backgroundColor: bgcolor,
      textAlign: 'right',
      iconName: '',
      iconAlign: '',
      iconColor: '',
JenniferAcunto
- Jen
ellipsol
New Contributor III
return
return {
  cells: {
    LT2_Difference: {
      textColor: tcolor,
      textAlign: 'right',
      iconName: '',
      iconAlign: '',
      iconColor: '',
