Formatting cell values of a table added with table widget to dashboard
2067
02-28-2024 09:38 AM
ellipsol
I added a table widget and connected it with a table in a dashboard. I want to format select cell values. I'm think I could manage this with Arcade, similar to what's below. Is there a way to handle this table formatting in a dashboard?
var bld = Concatenate('<strong>'+$feature.LT2_Difference+'</strong>')
# Format where values are less than or equal to -1
var val = When($feature.LT2_Difference <= -1, bld, $feature.LT2_Difference);
return{
LT2_Difference: {
      displayText : val,
      textColor: '',
      backgroundColor: '#e0e0e0',
      textAlign: 'left',
      iconName: '',
      iconAlign: '',
      iconColor: '',
      iconOutlineColor: ''
2 Solutions
JenniferAcunto
You can find the Advanced Formatting for tables under the Values tab. Each column will have its own section of the return statement.
- Jen
ellipsol
Thank you, I misspoke and realize I was trying in Experience Builder, not a Dashboard. I got a minimum working example with your response, in a Dashboard.
var bgcolor = When($datapoint.diffVal <= -1, '#CC0000', '')
var tcolor = When($datapoint.diffVal <= -1, '#111', '')
return
return {
  cells: {
    LT2_Difference: {
      displayText : $datapoint.diffVal,
      textColor: tcolor,
      backgroundColor: bgcolor,
      textAlign: 'right',
      iconName: '',
      iconAlign: '',
      iconColor: '',
JenniferAcunto
- Jen
ellipsol
return
return {
  cells: {
    LT2_Difference: {
      textColor: tcolor,
      textAlign: 'right',
      iconName: '',
      iconAlign: '',
      iconColor: '',
EllieLinden
Is there a plan to allow for value formatting options (e.g. Setting Digit grouping, Maximum decimal places, etc.) directly to the ArcGIS Dashboard table widget to avoid the need to use Arcade within Advanced Formatting?
