format for the save results in parameter in the find find existing locations tool
1429
10
09-05-2024 12:41 PM
Laura_m_Conner
All,
In portal on a web mapping application I was asked to add the capability of  selecting features based on a selected polygon. To accomplish this I add the analysis widget with the find existing locations function. I have gotten my layers picked and the expression written. The trouble is with the save results in perimeter. I tried putting in a network path it did not work. I have tried asking the chat bot on technical support it said to use the flowing format: {"layerId": "<layer_id>", "tableName": "<table_name>"}. I tried using the answer verbatim and it still said it was not a valid entry. What do I need to put in  the save results in parameter to get it to run? also is there a way to hard code or set to a defult value that always populated with the same value? The people who are going to be using this tool are not the ones for technical jargon and would get annoyed at the doing it every time.
portal 10.6.1
Thanks.
Laura_m_Conner
It's doing the same thing for summary statistics and Summarize Nearby tool. The use is infrequent enough not to worry about credits so I am shifting it to ArcGIS online.
