Floor Filter Widget ArcGIS Online Map Viewer
593
07-18-2022 02:53 AM
denniszammarchi
I took the data from the ArcGIS Indoors Building L Sample and then I republished them on my AGOL (I don't have the indoors license), is it correct that the floor filter range widget does not work in the map viewer?
Thank You
RussRoberts
Esri Notable Contributor
RussRoberts
You will need an indoors license to publish a web map https://doc.arcgis.com/en/indoors/viewer/prepare-a-map-for-indoor-viewer.htm
