Find Route - How do I restrict the route to a 7 hour day?
1097
12-06-2016 10:06 AM
GavinMayeda
I am working with the Find Route tool, and I don't see a way to restrict routes to a set time duration.
In ArcLogistics, I could enter  stops, and then restrict the routing to a set number of hours worked in a day.  Can this be done in the Find Route tool?
As always, thank you in advance for any suggestions and solutions!
Dell OptiPlex 9010
Intel(R) Core(TM) i7-3770 CPU @ 3.40 GHz
8.0 GB RAM
Windows 7 Professional 64-bit OS
AMD Radeon HD 7570
Dual Dell U2414H Monitors
GavinMayeda
Ok, after poking around I was able to find the time constraints in the Properties of the 'Stops' tab.  I don't see a way to set the properties for ALL stops though, so I am forced to set Stop Duration and Time Window for each stop. Still muddling my way through this.  I will say that it is far easier than using the old ArcLogistics so far.
