Field Calculations in form not working when editing in ArcGIS Pro
813
10-15-2024 09:23 AM
Justin_Greco
I have set up some field calculations in a form in a Map Viewer, when I open that map in ArcGIS Pro, none of the calculations are running.  Do the forms not translate over to ArcGIS Pro?
bbollin
Hi @Justin_Greco, thanks for your question. At this time, Forms are not supported in ArcGIS Pro. To take advantage of forms you'd need to use Map Viewer, Field Maps, or any of the other products that support Forms.
Hope this helps
bbollin
Hope this helps
ChristopherCounsell
MVP Frequent Contributor
Might want to remove Survey123 from the list of apps that support map viewer forms.
