Features created using Survey123 appear in my Map, but not the app I create
361
03-28-2025 02:48 AM
SimonCrutchley
Hi there,
I'm new to using Survey123, but I don't think this is down to the underlying data, though if you think otherwise, I'm happy to be corrected. I've created a form that allows me to collect data, and then I've copied that data layer back into the app, so that others can see it. However, although the points appear quite happily in the map (Map view, not Classic), complete with pop-ups etc, and they appear for me in the app I've built (Experience Builder) (see screenshot), they don't appear for others. To be more precise, the layer appears in the layer list, but no data points appear.
This is the app - https://experience.arcgis.com/experience/4de840d1733f49eb9d1cad0f6fc070ca/?draft=true and the layer in question is 'Downs from Above (Mk2) - Latest contributions.
I can't see how it could be anything to do with sharing as otherwise people would be asked to sign in to access the app, so I don't understand what's going on.
Ta
SimonCrutchley
I discovered there was a setting in the settings that needed changing. User error ☹️
SimonCrutchley
