Feature Layer records appear blank but are still storing data
274
10-24-2025 02:04 PM
natalietarbox_audubon
Hello all,
I have a point feature layer that is populated by a survey 123 connect survey form. Users have been filling out this form for weeks with no issues, and the data is populating correctly in the feature layer. Starting Oct 21st, all records previously submitted started appearing blank in the feature layer. All records submitted after Oct 21st appear as expected.
These blank records still hold data (the web map view shows all data points, with correct and complete pop-up info, and I can see the info contained within map filters). They just appear blank, but somehow, the data is being stored still.
When I pull it into Pro, the data populates correctly and all records are complete (no blanks, unlike in AGOL). I have tried truncate and append in ArcPro to re-create those records, but this did not fix the issue. Has anyone experienced anything like this before, or have any ideas for fixes I should try so the blank records are populated correctly again?
Any help is much appreciated, thank you!
EmilyGeo
Hi @natalietarbox_audubon
Just to clarify, you said that the pop-ups are working as expected. And that features appear on the map. Where is it that they appear blank?
Hello, ~100 of the features appear blank in the 'Data' tab of the hosted feature layer. I am unable to edit them or click on these blank features in the 'Data' tab.
