Feature Layer randomly loosing symbology.
967
09-30-2024 01:44 PM
Labels (2)
RachaelMurtaugh
I'm working on an address layer for our solid waste crews. They symbology is doubled with different colors for pick up days and different shapes for the trucks. However, seemingly at random, I loose the symbology and even the label settings and the data became uneditable. Any thoughts? I had to export in ArcPro and republish.
bbollin
Hi @RachaelMurtaugh, can you provide more detail about your process? Are you publishing in pro and loosing the symbology in arcgis online? Are you saving the configurations to the item itself?
RachaelMurtaugh
The symbology saved and was working great. I was editing and doing all of my normal work. I symbolized it in Pro months ago. Then seemingly one minute to the next, the shapes and colors are all black dots, and I can't edit it. When I try to edit the attributes or add points, I get this.
bbollin
@RachaelMurtaugh did you change any of the schema for this dataset? If you can share it publicly I can take a look
RachaelMurtaugh
Here is the link. I just made it public. SolidWastePickUpAddressesDataAndRouting - Overview (arcgis.com)
