Feature Layer (hosted, view) new field creation
2004
09-30-2022 12:51 PM
Labels (2)
drWood
Hello all,
Recently one of our online services required a new field to be added to one of our feature services for display within a dashboard utilized by the public. I added the new field to be displayed within the hosted feature layer and populated the new field with the necessary data.
When accessing the hosted view layer for this hosted layer the new field does not appear in the table at all. The new field still shows in the hosted feature layer in webmaps that have the hosted feature layer in it, but is not visible in any other views.
I was under the assumption that all edits should carry over to the other views. Any ideas on what is going on and how to address it? Thank you in advance!
-Derek Wood
Alfred_Baldenweck
To your final point, all edits do carry over to the other views, but if they aren't relevant (e.g. filtered out via definition query, or those field weren't included) they won't show up.
That being said, I figured it out.
On the View, go to Settings, then Update View. You should be able to change the fields there.
EduardoDiaz
Did you update the layer using Pro? (Append Tool) or how you update the data? https://support.esri.com/en/technical-article/000020494
My first tought is the webmap who is used in dashboard´s is not the same who have the layer that you refresh.
drWood
The new field was added to the hosted feature and populated with data directly in AGOL. All of the updates to the data are done within the hosted layers and typically displayed within the hosted views automatically. For some reason the creation of a new field is not carrying over to the hosted views though.
Alfred_Baldenweck
drWood
Thank you for tracking down the source of my problem! I was unaware of the need to update the views through the details page.
