Failing to Publish a hosted feature layer to ArcGIS Online
2415
12-02-2019 01:07 AM
Jean_PierreGatera
While publishing to a hosted feature layer to ArcGIS Online (user is a creator/publisher or administrator, both with the same result), the following are the errors we get with different publishing scenarios:
- trying to publish with ArcGIS Pro (2.4.2) failed with this log file:
      We also tried with ArcMap with the same result.
- trying to upload (add item) a zipped shape file and publish it as hosted layer:
- trying to create a layer from a template within AGOL like
    This doesn’t bring an error message but just turns grey for a second or two and goes back to the blueish version but doesn’t do anything in the end.
This is a newly setup subscription with many users and many credits so it can’t be a credits issue.
The health status also doesn’t show any issues from the system.
Any ideas?
DeidreWolf
Hello Jean Pierre Gatera is this a new ArcGIS Online subscription? Can anyone in the organization publish or create a hosted feature layer? If no one in the organization can publish or create a hosted feature service in the ArcGIS Online organization, I recommend you log a support ticket with Esri Technical support.
SangHyouk_Oum
Any update on this? I am having the same issue. I have been trying all different ways to publish but keep failing.
YanSong
Hi did you solve the problem? I'm having the same issue
FC_Basson
How many features are in the shapefile?  Limit is 1,000 I think.
What browser are you using? If Chrome, try publishing from Incognito mode.
