Failed to publish web layer (hosted feature service) on a new organization
2865
12-10-2020 03:11 AM
PanGIS
Hi!
I have just created a new organization for a customer, I am the (temporary) admin and creator of the organization.
I have already published these services on my own organization without problems, now I need to republish them on the new organization and hand over to the owner.
I cannot publish them. I created other 2 members to test, one is creator/publisher but nothing works.
I tried to publish from ArcGIS PRO 2.6.2 and ArcMap 10.6.1. also I tried to publish the SD file  from AGOL but also fails.
If I switch to my own organization it works.
Any idea?
PanGIS
Hi Peter,
the case was successfully solved by the Online operations team.
You have a DM
by Anonymous User
Not applicable
Hi @PanGIS thanks for the post.
  • Can you test creating a feature layer from a template in the Content page within ArcGIS Online and let me know if this works?
    • If it does work, can you try publishing the SD file again?
    • If it does not work, can you let me know the error seen in the Developer tools network tab?
If creating a layer from a template fails, I think we should probably get this issue into Esri Support - they'll work with the Online operations team to address the issue with the new organization - feel free to send me an email at [email protected] and I can get a case started for you.
-Peter
PanGIS
Hi @Anonymous User
thank you for your reply.
the template test failed too.
I logged a case with TechSupport and now they are taking care of it.
I can update you on the resolution if you are interested or if you are able to see the internal cases I can send you the case number in private.
thanks
by Anonymous User
Not applicable
Thanks for the update; I am able to see internal cases so if you can direct message me the case number that would be perfect.
Thanks again,
-Peter
PanGIS
Hi Peter,
You have a DM
