Export to CSV broken when using Arcade Attribute Expression
1629
03-05-2023 12:59 PM
suburbanMapper
Hi all,
I have a web app utilizing the "Export to CSV" functionality in the Attribute Table widget. I have insured this is checked-on in the widget settings.
I am also using Arcade Attribute Expressions to calculate some fields in the pop-up that will also be available in the attribute table and subsequent CSV. This works as expected until I add the expressions below. Then the export to CSV freezes and never completes. The expressions buffer a linear feature and return the lat/long of the centroid.
Latitude
var PatchBuffer = Buffer($feature, 10)
var PatchCentroid = Centroid(PatchBuffer)
return round(PatchCentroid.Y, 6))
Longitude
return round(PatchCentroid.X, 6)
Attibute expressions are being leveraged for a number of other fields and these are exporting as expected. The exports fail when the above expressions are added.
I have isolated the problem but am a little lost on how to resolve it. Any ideas are welcome.
DavidGrafton_BadElf
Have you tried just using the geometry attributes of the feature?  Is the buffer doing anything here?
i.e
var lat = geometry($feature).y
var lon = geometry($feature).x
suburbanMapper
The features are linear, so they do not have an explicit X/Y available.
The buffer is creating a polygon to get the centroid lat/long.
It appears this is a known bug, BUG-000131959. I was hopeful someone had a workaround.
