ESRI Basemap is not clear when we zoom in to fullest available level, where as Google map is very clear
592
06-01-2023 10:13 PM
Vara_PrasadM_S
Hi Team,
For the location of our data, ArcGIS Basemap - "Hybrid" is not clear when we zoom in to the fullest available level. Where as we can see the details clearly in Google maps.
Is there any other basemap which gives the clear details which we can use in ArcGIS Server JS API 4.X based application.
Thanks in advance!
Here are screenshots:
Google Maps:
ESRI Hybrid base map:
With Regards,
Vara Prasad
BernSzukalski
Esri Frequent Contributor
Both Imagery and Imagery Hybrid basemaps are identical in terms of the imagery they provide. You can open this layer, then zoom to your area of interest (make sure you zoom as the metadata is scale-dependent), to get information about the resolution, accuracy, acquisition data, and source.
https://www.arcgis.com/home/item.html?id=c03a526d94704bfb839445e80de95495
You can also use this app to view current, and planned, updates to imagery:
https://www.arcgis.com/apps/MapSeries/index.html?appid=27236479807f43e9ac3ff65d6777e324
Our goal is to publish the very best available imagery from user contributions and commercial sources like Maxar. Depending on your area of interest, the content may vary. Let me know which area you are focused on. Otherwise, the latest and best is always published in our Imagery and Imagery Hybrid basemaps.
