ESRI App and Android Phones
1965
08-28-2012 12:08 PM
goatessteve
I have several webmaps up and running on iPhones where users are editing data in the field.
Just tried them all on an Android device and it bombs every time when the user tries to edit.
What causes this and how can i fix?
Thank you!
goatessteve
More info:
Android Device is running android version 2.3.4
Baseband version 2.15.10.12.20
build number 4.08.605.15 CL389630 release-keys
Software number 4.08.605.15 710RD
Browser version WebKit/533.1
PRI version 1.70_002
LiLin1
by Esri Contributor
Could you please share the webmap that failed to edit on Android? Where in the editing process did it crash? picking a feature from the template or while collection geometry?
Could you please try the webmap in collection samples under Gallery to see if it works for you? Collection samples are Esri hosted feature service, they are sample for people to try data collection workflow.
Thank you.
Scottschrader
Had the same issue.  what worked for me was to include:
"widgets": {"editor": {}}, in my json. solved this issue by stealing json code from arcgisonline as described in:
http://help.arcgis.com/en/arcgismobile/10.0/apis/iphone/AppGuide/Maps.pdf
Now the mobile service works in both iOS and 'droid'
scott
goatessteve
Thanks very much Scott, i will give that a try.
