I am trying to add data from ArcGIS Online from ArcMap and keep getting an error message saying Unable to connect to ArcGIS Online. I am, however, able to sign into my account from any browser I open with no problems whatsoever. I'm not sure what is happening here. I even uninstalled Mcafee.
Solved! Go to Solution.
Try opening ArcGIS Administrator > Advanced... > Manage Portal Connections... > what is listed here? Make sure it says https://www.arcgis.com
Hi Natasha,
In addition to Scott's suggestion, it's probably worthwhile to check the ArcGIS Online connection utility test for any helpful errors. To do so:
1. With ArcMap open, right-click the little globe icon in the system tray of your computer:
2. Select "Run Connection Test." Any failures there? Hopefully that can clarify what's causing the error.
-Lauren
Hi Lauren thankyou for your response.
I did run the Connection Test and everything passed.
I restarted the computer after having uninstalling Mcafee and that seemed to do the trick here.
Perhaps it was a firewall notion.
Thankyou for your response.
~ Natasha
I'm having the same problem earlier. Thanks for this tips 😁
Very much appreciated
