Error exporting data to filegdb format
4325
04-26-2016 06:43 PM
MatthewSkewes2
Hi
I have a feature service with attachments (750 Photos @ 2-3mb) that I'm trying to download but using the export to FGDB option I continually get this error - Error exporting data to filegdb format
Does anyone have any ideas on why this is occurring and how I can go about pulling the data down.
Regards
DanPatterson_Retired
MatthewSkewes2
Yeah I gave that a go but I get this error when running the script - ImportError: No module named 'urllib2'. So not having to much luck at the moment
urllib2 is a python module... by chance, do you not have python installed on your machine?  I would suspect you would if you also have arcmap
MatthewSkewes2
Yeah I have python installed, not sure what the issue is I'm running the toolbox through ArcGIS pro
that needs to be replaced, since it is using python 3... run it through arcmap  It has been split into two as of python 3
20.6. urllib2 — extensible library for opening URLs — Python 2.7.11 documentation
