Enable Sync, keeps giving me a "Save wasn't successful. Try Again Later"
3975
8
02-13-2024 10:58 AM
BryanMJewell
I'm trying to Enable Sync so my layer I create will show up in the Field Maps app so data can be collected. When I try to  Enable Sync and save it keeps giving me a "Save wasn't successful. Try Again Later" error message. However, it does not give me that error if I just Enable Editing.
Any ideas?
cat206
If the above from Alexa doesn't help, have you got any layer views for this layer? I found this bug is causing my error BUG-000140593 for ArcGIS Online (esri.com)
GarrettJohnson
Having same issue without solution yet.
SekouToure
Like many errors in ArcGIS, they will not explain why, and you will not find solution. It's just a commercial. Pay your license and use free softs.
AlexaKennel
Maybe you've already solved this by now, but check if any of your fields are the following types:
  • 64-bit object IDs
  • Big integer
  • Date only
  • Time only
  • Timestamp offset
I had a Date only field that was causing the same error. I changed it to a date field instead and it saved no problem. I was able to connect it to field maps. I found this solution on this page: Manage hosted feature layer editing—ArcGIS Online Help | Documentation.
Hope this helps!
LayerItOn
Yes! You are a life saver! I added a new layer and a field was "Date Only" and that was preventing me from saving with "Enable Sync." Once I deleted that I could save.
Thank you @AlexaKennel
ChristinaVarnava
This was it for me too, thank you so much!
cat206
LarryW
That has got to be one of the lamest error messages ever concocted by the human mind. How is trying again later supposed to solve somebody's problem?
LarryW
Did "Try again later" solve anybody's problem??? No. The error message is lame because it advises people to do something that doesn't solve the problem, wasting their time. No information is better than wrong information. I would expect ESRI to know that.
