Editing not always available in AGOL App
678
06-20-2019 12:11 PM
CynthiaKozma
Occasional Contributor II
I have built a Web Map Application to edit a permitting layer based on an ArcGIS solution.  The feature layer is created by loading our data into the solution through ArcGIS Pro.  If I open the Web Map, the editing attribute popup always comes up and I can edit the layer.  However, when I open the Application that is created from this web map, sometimes I get the attribute editing popup and sometimes I can only get the identify popup.  I have not figured out the rhyme or reason to this.   Does anyone have any ideas as to why this happens?  This really needs to have that editing popup every time.  I don't know if this is just a bug because I am using a solution.
DerekLaw
Esri Esteemed Contributor
Hi Cynthia,
> I have built a Web Map Application to edit a permitting layer based on an ArcGIS solution.  ... However, when I open the Application that is created from this web map, sometimes I get the attribute editing popup and sometimes I can only get the identify popup.
Can you please tell us the name of the ArcGIS Solution? Which solution template are you using? For which industry, as there are many: ArcGIS Solutions Applications | ArcGIS Solutions
CynthiaKozma
Hi Derek,
I edited the ROW Permit Dashboard solution (Local Government) to work with our Planning Departments permits.  I have created an entirely new Web Map Application and, so far, it seems to be working consistently.  The original one I made still only works intermittingly.
DerekLaw
Hi Cynthia,
That is good to hear.
