Download Item from AGOL using token and keep the Item unshared
850
08-07-2017 01:26 AM
AlexanderFischer
I'm trying to download item from AGOL that i had already uploaded, according to the REST API documentation :
http://resources.arcgis.com/en/help/arcgis-rest-api/index.html#/Item_Data/02r300000075000000/
the download could be done using link but token is not mentioned, I tried to use the token but it's not possible, The only way to used the above approach is by sharing the item, and then use the suggested link to download the Item, is there any other way to download AGOL item without sharing it and using the token?
Jimmy
KellyGerrow
Esri Alum
Hi Jimmy,
Each username and password can generate a token. If the item is shared with the user who is generating the token, then the download will work with the appended token.
Generate token
Ensure you check out the Licensing Agreement to understand how to use the sharing model.
Terms of Use | ArcGIS for Developers
http://www.esri.com/legal/pdfs/mla_e204_e300/english
-Kelly
KellyGerrow
Esri Alum
Hi Jimmy,
Generate token
-Kelly
