Hi all, quite new to ArcGIS Online. How do I go about displaying the coded value descriptions instead of the coded values in a popup within AGO?
Nicole,
I don't think this is possible.
Maybe before you publish the service, open the attribute table, click on Table Options -> Appearance and uncheck "Display coded value domain and subtype description".
Tim
That's too bad.
Thanks Tim
Hi Nicole,
ArcGIS Online should use the domain descriptions by default. Are you using a hosted feature service or an ArcGIS Server service?
Hi Jake,
I thought the descriptions would come up by default as well. I am using a hosted feature service.
Take a look at the following blog:
http://blogs.esri.com/esri/arcgis/files/2014/10/How-to-Update-Hosted-Feature-Service-Schemas1.pdf
You can check the domain and it's associated value/description through REST. You could also update the value to match the description, though I have tested this and you should not have to.
I'm sorry, I was mistaken. We are using an ArcGIS Server service instead of a hosted feature service for the layers that I am having problems with.
But this article is very handy to have for other issues that may pop up.
My domains I set in the MXD/GDB do come over in AGO web maps, at least in the default web map. They do not persist in Open Data, and that is a problem for us. Trying a work around to see how I can still get this info to users since that is the whole point of why I wanted to use domains.
Signed in members can post, follow updates, and more. New here? Register a free account.
