Display one country arcgis online basemap
5124
04-23-2019 05:11 AM
DambéSANWOGOU
Is it possible to display only one country on the default ArcGIS Online map?
Best regards,
Anselme
Tags (3)
Egge-Jan_Pollé
Hi Dambé SANWOGOU‌,
Yes, that is possible.
You can create a Tile Layer showing only the country you are interested in (Togo) and set this as your basemap.
Egge-Jan
Scott_Harris
Just a suggestion:
  1. Add > Browse Living Atlas > search for World Countries and add it to the map.
  2. Filter the layer with the following expression: COUNTRY is not Togo
  3. Set the symbology on the layer to the desired color and be sure remove the outline color(no color).
DambéSANWOGOU
Thanks for your answer, I managed to do it but when I zoom and zoom in and out, there are some countries that appear, it doesn't make the map pretty.
