Dimension of a 3D cylinder not measured correctly in Arcgis online?
1541
11-03-2022 12:54 AM
JohannesBierer
Hello,
I've a problem with the measure tool in ArcGIS online. I exported a ArcGIS Pro (2.9.3) Scene to ArcGIS online and put the scene in the experience builder. In the scene there is a 3D cylinder with a hight of 450m and a diameter of 1000m.
But in the experience builder I can only measure a diameter of 650m instead of 1000m? See attached images ...
Any ideas what could be the problem?
JohannesBierer
There's an answer from ESRI. I've edited the 3D object in the wrong coordinate system (WGS 1984 Web Mercator (auxiliary sphere)) which causes the wrong measurements.
RussRoberts
Esri Notable Contributor
can you share the web scene?
JohannesBierer
Unfortunately I can't share it here in geonet. In addition I have delete the hole scene. But I could recreate it. Maybe there is a way to share it with you personaly?
RussRoberts
create a group and invite russell_jsapi into it have have the content there.
JohannesBierer
JohannesBierer
Thank you for your help and I've invited you. I think the size of the half cylinder now look similar to ArcGIS Pro, only the measurement tool result in different meters?
