Determining which maps have offline areas in the "Managed Offline Areas"
389
09-23-2025 05:18 AM
Labels (2)
MichaelBruening
I am trying to find if there is a means of programmatically determining which Map Viewer within my ArcGIS Online organization has Maps that are currently set to package map packages. I need to run through and stop some of these maps that have this functionality set up for them. I provide a screenshot below of the area that I am talking about.
Any ideas would be greatly appreciated.
gis_KIWI4
MVP Regular Contributor
@MichaelBruening - You can use a python notebook in AGOL.
Run the below code -
from arcgis.gis import GIS
import pandas as pd
gis = GIS("home")
# Search org
webmaps = gis.content.search(
    query='type:"Web Map" AND typekeywords:"Offline"',
    max_items=10000,
    outside_org=False
rows = []
for wm in webmaps:
    # offline areas
    areas = wm.related_items("Map2Area", "forward")
    if areas:
        for a in areas:
            rows.append({
                "webmap_title": wm.title,
                "webmap_id": wm.id,
                "map_area_title": a.title,
                "map_area_id": a.id
df = pd.DataFrame(rows)
df
You should see a list of all webmaps and the areas associated with them.
MichaelBruening
Hello, I will run this code on either Monday or Tuesday and let you know what happens. I appreciate you sharing this and will return with an answer
