Delete domain in ArcGIS Online
2165
05-27-2022 01:11 PM
BenJackson
I created a domain for a field, and now I need to delete it. I cannot seem to be able to do it in ArcGIS Pro, and there is no option online that I can see. Any ideas?
Katie_Clark
MVP Regular Contributor
In AGOL, domains are called "lists". You can access the current domain/list for a field by clicking on the "Data" tab in the Item Details page, then "Fields" view, then click the name of the field you want to remove the list for. On that page, click the pencil icon to edit the current list. Within that view, there is a button to "Delete List" in the lower left.
Hope that helps!
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Hope that helps!
Best,
Katie
BenJackson
Thanks, I couldn't see the delete list button first time for some reason.
