So I have a need for a GeoForm that will concatenate multiple fields into a single field.
Currently I am using the GeoForm to create 'Pending Addresses' inside the Site Address Points from the Local Government Model.
I have already worked with the GeoForm GIT Editors and they have customized the form to offer the ability to 'Lock' a field so that it is VISIBLE but not EDITABLE to EndUsers. Basically, in the JSON under [form folder]/config/default.js you can create an assortment of attributes for 'fields' made available in the form. The KEY attribute being the "name" attribute which identifies the Feature Class field this HTML form will be pushed into.
Well, using the newly updated [form folder]/js/main.js file you can now add "locked": true and that field will be greyed out and uneditable to end users. Something MUCH needed for my current (and many future) project(s).
ANYWAY... since I was able to visibly see the Javascript used to add this functionality to the GeoForm I have decided to try my hand out at editing the [form folder]/js/main.js file to add another functionality that is GREATLY needed for this form.
CONCATENATION
Think "THIN" Attribute Assistant for the GeoForm. (very thin)
Basically, in this current instance (Site Address Points) I want to be able to display the FULLADDR and FULLNAME fields from SiteAddressPoints AND have them Auto-Populate with the concatenated contents from other fields.
Specifically from ADDRNUM, PREADDRNUM, STREETNAME, STREETTYPE, ADDRNUMSUF, UNITTYPE, UNITID
So... this is my goal. I'm going to be asking a LOT of questions as this is the first for me in a long time for working with Javascript, first forever in working with Dojo, and I am hoping this will lead to more custom development in my group.
So my questions are as follows:
I am numbering them so that answers can be assigned to those numbers.
As I need to get this process moving I have also posted this question over at Stack Exchange in case anyone else is following this and also uses Stack Exchange.
I customized the MAIN.JS and DEFAULT.JS files to allow for concatenated fields. I think I am going to try to use this experience to start work on an ATTRIBUTE ASSISTANT widget. We shall see...
"name": "FULLADDR", // field id
"alias": "Full Address", // label
"fieldDescription": "The Full Address as in 175 E 2ND ST S for 175 E 2ND ST S", // Help text
"visible": true, // show this field?
"typeField": false, // subtype field?
"tooltip": "175 E 2ND ST S, SUITE 3", // placeholder text
"locked": true, // is this field editable on the main form?
"concatenator":
 "ADDRNUM", " ", "PREADDRNUM", " ", "STREETNAME", " ", "STREETTYPE", " ", "ADDRNUMSUF", ", ", "UNITTYPE", " ", "UNITID"
"displayType": "text" // text, checkbox, radio, textarea, url, email
My thoughts being that I would need to reference the CONCATENATOR field/attribute and it would contain a list of TEXT objects. I would convert any of them to either a pointer to the field ID... much like:
<input type="text" class="form-control" data-input-type="String" maxlength="20" id="ADDRNUM" placeholder="175" data-display-type="text">
So unless there's a smarter way of setting this up? I think that would work for the JSON setup.
So I am getting JSON errors and I'm assuming its for how I am trying to reference the fields to concatenate.
Any ideas?
Here is my customized default.js JSON file for the new GeoForm. Use it as an example if you are interested.
define({
 //Default configuration settings for the applciation. This is where you"ll define things like a bing maps key,
 //default web map, default app color theme and more. These values can be overwritten by template configuration settings
 //and url parameters.
 "appid": "*****",
"webmap": "*****",
 "form_layer": {
 "id": "Address_XXXX"
 "details": {
 "Title": "Pending Addressing",
 "Logo": "http://SERVERNAME/geoforms/NewAddress/images/logo.png",
 "Description": "A web map for placing new addresses that are pending review and approval"
 "fields": {
 "Address_XXXX": [{
 "name": "CAPTUREMETH", // field id
 "alias": "Method of Capture for this Address", // label
 "fieldDescription": "How was this address found?", // Help text
 "tooltip": "Customer Suggested", // placeholder text
 "subscription": [
 "publication": "${0.value} ${1.value} ${2.value} ${3.value} ${4.value}, ${5.value} ${6.value}",
 "editorFields": [ "ADDRNUM", "PREADDRNUM", "STREETNAME", "STREETTYPE", "ADDRNUMSUF", "UNITTYPE", "UNITID" ],
 "required": [ "UNITID", "UNITTYPE" ]
 "publication": "${0.value} ${1.value} ${2.value} ${3.value} ${4.value}, ${5.value}",
 "editorFields": [ "ADDRNUM", "PREADDRNUM", "STREETNAME", "STREETTYPE", "ADDRNUMSUF", "UNITID" ],
 "required": [ "UNITID" ]
 "editorFields": [ "ADDRNUM", "PREADDRNUM", "STREETNAME", "STREETTYPE", "ADDRNUMSUF", "UNITTYPE" ],
 "required": [ "UNITTYPE" ]
 "publication": "${0.value} ${1.value} ${2.value} ${3.value} ${4.value}",
 "editorFields": [ "ADDRNUM", "PREADDRNUM", "STREETNAME", "STREETTYPE", "ADDRNUMSUF" ],
 "required": []
 "name": "FULLNAME", // field id
 "alias": "Full Name", // label
 "fieldDescription": "The Full Name of the road including any prefix or suffix as in E 2ND ST S for 175 E 2ND ST S", // Help text
 "tooltip": "E 2ND ST S", // placeholder text
 "subscription": [
 "publication": "${0.value} ${1.value} ${2.value} ${3.value}",
 "editorFields": [ "PREADDRNUM", "STREETNAME", "STREETTYPE", "ADDRNUMSUF" ],
 "required": []
 "name": "ADDRNUM", // field id
 "alias": "Address Number", // label
 "fieldDescription": "The Building Number as in 175 for 175 E 2ND ST S", // Help text
 "tooltip": "175", // placeholder text
 "name": "PREADDRNUM", // field id
 "alias": "Address Prefix", // label
 "fieldDescription": "The Address prefix as in E for 175 E 2ND ST S", // Help text
 "tooltip": "E", // placeholder text
 "name": "STREETNAME", // field id
 "alias": "Street Name", // label
 "fieldDescription": "The Street name as in 2ND for 175 E 2ND ST S", // Help text
 "tooltip": "2ND", // placeholder text
 "name": "STREETTYPE", // field id
 "alias": "Street Type", // label
 "fieldDescription": "The Street Type as in ST for 175 E 2ND ST S", // Help text
 "tooltip": "ST", // placeholder text
 "name": "ADDRNUMSUF", // field id
 "alias": "Address Suffix", // label
 "fieldDescription": "The Address suffix as in S for 175 E 2ND ST S", // Help text
 "tooltip": "S", // placeholder text
 "name": "UNITID", // field id
 "alias": "Unit Identifier", // label
 "fieldDescription": "The Unit Identifier as in 3 for 175 E 2ND ST S, SUITE 3", // Help text
 "tooltip": "3", // placeholder text
 "name": "UNITTYPE", // field id
 "alias": "Unit Type", // label
 "fieldDescription": "The Type of Unit as in SUITE for 175 E 2ND ST S, SUITE 3", // Help text
 "tooltip": "SUITE", // placeholder text
 "name": "PLACENAME", // field id
 "alias": "Place name", // label
 "fieldDescription": "The common name, or vanity name, for where the address is located.", // Help text
 "tooltip": "TULSA", // placeholder text
 "displayType": "text", // text, checkbox, radio, textarea, url, email
 "defaultValue": "Tulsa" // default value for the field
 "name": "MUNICIPALITY", // field id
 "alias": "Municipality", // label
 "fieldDescription": "The city or town of the address.", // Help text
 "name": "POINTTYPE", // field id
 "alias": "Type of Location", // label
 "fieldDescription": "A general description of the physical location represented by this address.", // Help text
 "name": "STATUS", // field id
 "alias": "Status", // label
 "fieldDescription": "The status of the address point.", // Help text
 "tooltip": "Pending", // placeholder text
 "defaultValue": "Pending",
 "locked": true
 "name": "SITEADDID", // field id
 "alias": "Site Address ID", // label
 "defaultValue": "GF" + new Date().getTime(),
 "locked": true,
 "fieldDescription": "The ID of the address point", // Help text
 "tooltip": "", // placeholder text
 FULLNAME: null
 FULLADDR: null
 PLACENAME: null
 ADDRCLASS: null
 POINTTYPE: null
 TPD_DIVISION: null
 ZIPCODE: null
 "theme": "basic", // see values in themes.js
 "oauthappid": null, // "*****"
 //Enter the url to the proxy if needed by the application. See the "Using the proxy page" help topic for details
 // //developers.arcgis.com/en/javascript/jshelp/ags_proxy.html
 "proxyurl": "http://cotgis/DotNet/proxy.ashx", // http://cotgis/DotNet/proxy.ashx
 //Example of a template specific property. If your template had several color schemes
 //you could define the default here and setup configuration settings to allow users to choose a different
 //color theme.
 //Enter the url to your organizations bing maps key if you want to use bing basemaps
 "bingmapskey": "",
 //Defaults to arcgis.com. Set this value to your portal or organization host name.
 "sharinghost": "https://cityoftulsa.maps.arcgis.com",
 "units": null,
 "useSmallHeader": true,
 "enableSharing": true,
 "defaultMapExtent": true,
 "pushpinColor": "blue",
 "nextBasemap": "satellite",
 "defaultBasemap": "streets-vector",
 "selectedTitleField": {},
 "disableViewer": false,
 "enableAttachments": true,
 "attachmentIsRequired": false,
 "attachmentLabel": "",
 "attachmentHelpText": "",
 "showLayer": true,
 "disableLogo": false,
 "enableBasemapToggle": true,
 "enableOfflineSupport": true,
 "locate": true,
 "locationSearchOptions": {
 "enableMyLocation": true,
 "enableSearch": true,
 "enableLatLng": true,
 "enableUSNG": false,
 "enableMGRS": false,
 "enableUTM": false
 "locationSearch": true,
 //When searchExtent is true the locator will prioritize results within the current map extent.
 "searchExtent": false,
 "searchLayers": [{
 "id": "",
 "fields": []
 "attachmentInfo": {},
 "submitButtonText": "",
 "viewSubmissionsText": "",
 "helperServices": {
 "geometry": {
 "url": null
 "printTask": {
 "url": null
 "elevationSync": {
 "url": null
 "geocode": [{
 "url": null
});The JSON has some new entries.
SUBSCRIPTION is one. You'll notice a new JSON object inside of it... It's important, if you have required fields and formatted output that you put the strictest requirements at the top of the file in descending order. Also, the order of the EDITORFIELDS in relation to the PUBLICATION field entries (i.e., ${0.value}, etc) is important. Make sure the fields are in the order you want them. Also the required fields is an array. You can set a publication to have fields that need to be filled out before it populates and it will check ALL of those fields. If any are missing that publication is skipped.
ALSO Make sure to have a publication with NO requirements unless you are ok with NOTHING happening if your requirements aren't met.
Here is the customized MAIN.js file. Make sure you use the new JSON from my default.js as well.
/*global $,define,document,require,moment */
/*jslint sloppy:true,nomen:true */
define([
 "dojo/_base/declare",
 "dojo/_base/kernel",
 "dojo/_base/lang",
 "dojo/topic",
 "dojo/string",
 "esri/dijit/BasemapToggle",
 "esri/arcgis/utils",
 "esri/config",
 "dojo/dom",
 "dojo/dom-class",
 "dojo/dom-style",
 "dojo/on",
 "dojo/Deferred",
 "dojo/promise/all",
 "dojo/query",
 "dojo/io-query",
 "dojo/_base/array",
 "dojo/dom-construct",
 "dojo/dom-attr",
 "esri/dijit/LocateButton",
 "esri/dijit/Search",
 "dojo/text!views/modal.html",
 "dojo/text!views/user.html",
 "dojo/i18n!application/nls/resources",
 "esri/tasks/ProjectParameters",
 "esri/geometry/webMercatorUtils",
 "esri/geometry/Point",
 "esri/layers/GraphicsLayer",
 "application/ShareModal",
 "application/localStorageHelper",
 "esri/graphic",
 "esri/symbols/PictureMarkerSymbol",
 "esri/toolbars/edit",
 "esri/InfoTemplate",
 "esri/dijit/Popup",
 "application/themes",
 "application/pushpins",
 "application/SearchSources",
 "vendor/usng",
 "dijit/a11yclick",
 "dojo/NodeList-traverse",
 "application/wrapper/main-jquery-deps",
 "dojo/domReady!"
], function (
 declare,
 kernel,
 lang,
 topic,
 string,
 basemapToggle,
 arcgisUtils,
 esriConfig,
 dom,
 domClass, domStyle,
 on,
 Deferred,
 all,
 query,
 ioQuery,
 array,
 domConstruct,
 domAttr,
 LocateButton,
 Search,
 modalTemplate,
 userTemplate,
 nls,
 ProjectParameters,
 webMercatorUtils,
 Point,
 GraphicsLayer,
 ShareModal,
 localStorageHelper,
 Graphic,
 PictureMarkerSymbol,
 editToolbar,
 InfoTemplate,
 Popup,
 theme,
 pushpins,
 SearchSources,
 usng,
 a11yclick) {
var NORTHING_OFFSET = 10000000.0; // (meters)
return declare([], {
 arrPendingAttachments: [],
 objFailedAttachments: {},
 arrRetryAttachments: [],
 flagAttachingPrevFile: true,
 nls: nls,
 config: {},
 map: null,
 addressGeometry: null,
 editToolbar: null,
 themes: theme,
 pins: pushpins,
 localStorageSupport: null,
 defaultValueAttributes: null,
 sortedFields: [],
 isHumanEntry: null,
 currentLocation: null,
 dateFormat: "LLL",
 subscriptions: [],
 startup: function (config, appResponse, isPreview, node) {
document.documentElement.lang = kernel.locale;
this._appResponse = appResponse;
 var localStorageSupport = new localStorageHelper();
 if (localStorageSupport.supportsStorage() && localStorage.getItem("geoform_config")) {
 config = JSON.parse(localStorage.getItem("geoform_config"));
 localStorage.clear();
 // config will contain application and user defined info for the template such as i18n strings, the web map id
 // and application id
 // any url parameters and any application specific configuration information.
 if (config) {
 this.config = config;
 // create localstorage helper
 this.localStorageSupport = new localStorageHelper();
 // modal i18n
 var modalTemplateSub = string.substitute(modalTemplate, {
 title: "",
 labelId: "myModalLabel",
 close: nls.user.close
 // place modal code
 domConstruct.place(modalTemplateSub, document.body, 'last');
 //supply either the webmap id or, if available, the item info
 if (isPreview) {
 this._initPreview(node);
 } else {
 this._init();
 } else {
 var error = new Error("Main:: Config is not defined");
 this.reportError(error);
_loadCSS: function () {
 var cssStyle;
 cssStyle = dom.byId("rtlCSS");
 cssStyle.href = "js/vendor/bootstrap-rtl.min.css";
_init: function () {
 var userHTML, itemInfo;
 // no theme set
 if (!this.config.theme) {
 // lets use bootstrap theme!
 this.config.theme = "basic";
 // set theme
 this._switchStyle(this.config.theme);
 if (this.config && this.config.i18n && this.config.i18n.direction == "rtl") {
 this._loadCSS();
 userHTML = string.substitute(userTemplate, nls);
 dom.byId("parentContainter").innerHTML = userHTML;
 // get item info from template
 itemInfo = this.config.itemInfo || this.config.webmap;
 // create map
 this._createWebMap(itemInfo);
 // if small header is set
 if (this.config.useSmallHeader) {
 // remove class
 domClass.remove(dom.byId('jumbotronNode'), "jumbotron");
 _initPreview: function (node) {
 var cssStyle;
 // if local storage supported
 if (this.localStorageSupport.supportsStorage()) {
 localStorage.setItem("geoform_config", JSON.stringify(this.config));
 // set theme to selected
 array.forEach(this.themes, lang.hitch(this, function (currentTheme) {
 if (this.config.theme == currentTheme.id && currentTheme.url) {
 cssStyle = domConstruct.create('link', {
 rel: 'stylesheet',
 type: 'text/css',
 href: currentTheme.url
 //Handle case where edit is first url parameter we'll use the same logic we used in ShareModal.js
 var url = 'https://' + window.location.host + window.location.pathname;
 if (window.location.href.indexOf("?") > -1) {
 var queryUrl = window.location.href;
 var urlParams = ioQuery.queryToObject(window.location.search.substring(1)),
 newParams = lang.clone(urlParams);
 delete newParams.edit; //Remove edit parameter
 delete newParams.folderid; //Remove folderid parameter
 url = queryUrl.substring(0, queryUrl.indexOf("?") + 1) + ioQuery.objectToQuery(newParams);
 node.src = url;
 // on iframe load
 node.onload = function () {
 var frame = document.getElementById("iframeContainer").contentWindow.document;
 var h = frame.getElementsByTagName('head')[0];
 if (h && cssStyle) {
 domConstruct.place(cssStyle, h, "last");
 _submitForm: function () {
 var btn = $('#submitButton');
 btn.button('loading');
 var erroneousFields = [];
 array.forEach(query(".geoFormQuestionare"), lang.hitch(this, function (currentField) {
 if (domClass.contains(currentField, "hasAttachment")) {
 if (domClass.contains(currentField, "mandatory") && query(".alert-dismissable", dom.byId("divColumn2")).length === 0) {
 this._validateUserInput(nls.user.requiredFields, currentField, query(".hideFileInputUI")[0].value, true);
 erroneousFields.push(currentField);
 return true;
 //to check for errors in form before submitting.
 //condition check to filter out radio fields
 if (query(".form-control", currentField)[0]) {
 //if condition to check for conditions where the entered values are erroneous.
 if (domClass.contains(currentField, "has-error") && query("select", currentField).length === 0) {
 //if condition to check for conditions where mandatory fields are kept empty.
 if ((query(".form-control", currentField)[0] && (query(".form-control", currentField)[0].value === "") && domClass.contains(currentField, "mandatory")) || (query(".filterSelect", currentField)[0] && (query(".filterSelect", currentField)[0].value === "") && domClass.contains(currentField, "mandatory"))) {
 var selectValue = query(".form-control", currentField)[0] ? query(".form-control", currentField)[0].value : query(".filterSelect", currentField)[1].value;
 this._validateUserInput(nls.user.requiredFields, currentField, query(".form-control", selectValue, true));
 } else {
 if (domClass.contains(currentField, "mandatory")) {
 var mandatoryValue = query(".form-control", currentField)[0] ? query(".form-control", currentField)[0].value : query(".filterSelect", currentField)[1].value;
 this._validateUserInput(false, currentField, mandatoryValue, true);
 //handle errors in radio and checkbox fields here.
 else {
 if (!query(".filterSelect", currentField)[0]) {
 if (domClass.contains(currentField, "mandatory") && query(".radioInput:checked", currentField).length === 0 && query(".checkboxContainer", currentField).length === 0) {
 this._validateUserInput(nls.user.requiredFields, currentField, query(".radioInput:checked", currentField), true);
 } else {
 this._validateUserInput(false, currentField, query(".radioInput:checked", currentField), true);
 array.forEach(query(".filterSelect"), lang.hitch(this, function (currentField) {
 if (currentField.value === "" && domClass.contains(currentField.parentElement, "mandatory")) {
 this._validateUserInput(nls.user.requiredFields, currentField, currentField.value, true);
 //this statement will remove the error message div at first and then will be applied if a valid location is not selected
 this._removeErrorNode(dom.byId("select_location").nextSibling);
 //conditional blocks to check and validate the form and show appropriate error messages.
 var errorMessage;
 if (erroneousFields.length !== 0) {
 if (!this.addressGeometry) {
 // reset submit button
 this._resetButton();
 // error message
 errorMessage = '';
 errorMessage += nls.user.selectLocation;
 this._showErrorMessageDiv(errorMessage, dom.byId("select_location"));
 var elementId;
 if (!erroneousFields[0].children[0].id) {
 elementId = erroneousFields[0].parentElement.children[0].id;
 domClass.remove(elementId, "has-success");
 } else {
 elementId = erroneousFields[0].children[0].id;
 $('html, body').animate({
 scrollTop: $("#" + elementId).offset().top
 }, 500);
 btn.button('reset');
 } else {
 if (this.addressGeometry) {
 this._addFeatureToLayer();
 } else {
 // error message
 errorMessage = '';
 scrollTop: $("#select_location").offset().top
 }, 500);
 reportError: function (error) {
 // remove loading class from body
 domClass.remove(document.body, "app-loading");
 domClass.add(document.body, "app-error");
 // an error occurred - notify the user. In this example we pull the string from the
 // resource.js file located in the nls folder because we've set the application up
 // for localization. If you don't need to support multiple languages you can hardcode the
 // strings here and comment out the call in index.html to get the localization strings.
 // set message
 var node = dom.byId("loading_message");
 if (node) {
 if (this.config && this.config.i18n) {
 node.innerHTML = this.config.i18n.map.error + ": " + error.message;
 } else {
 node.innerHTML = "Unable to create map: " + error.message;
 _centerPopup: function () {
 if (this.map.infoWindow && this.map.infoWindow.isShowing) {
 var location = this.map.infoWindow.location;
 if (location) {
 this.map.centerAt(location);
 _resizeInfoWin: function () {
 if (this.map.infoWindow) {
 var iw, ih;
 var h = this.map.height;
 var w = this.map.width;
 // width
 if (w < 300) {
 iw = 125;
 } else if (w < 600) {
 iw = 200;
 } else {
 iw = 300;
 // height
 if (h < 300) {
 ih = 75;
 } else if (h < 600) {
 ih = 100;
 } else {
 ih = 200;
 this.map.infoWindow.resize(iw, ih);
 // set symbol for submitting location
 _setSymbol: function (point, isMapClicked) {
 var symbolUrl, pictureMarkerSymbol, graphic, it;
 // use appropriate symbol pin image
 array.some(this.pins, lang.hitch(this, function (currentPin) {
 if (this.config.pushpinColor == currentPin.id) {
 symbolUrl = currentPin.url;
 // create symbol and offset 10 to the left and 17 to the bottom so it points correctly
 pictureMarkerSymbol = new PictureMarkerSymbol(symbolUrl, currentPin.width, currentPin.height).setOffset(currentPin.offset.x, currentPin.offset.y);
 // text info template
 it = new InfoTemplate(nls.user.locationPopupTitle, "${text}");
 // graphic for point
 graphic = new Graphic(point, pictureMarkerSymbol, {
 text: nls.user.addressSearchText
 }, it);
 // private geoform graphic identifier
 graphic._geoformGraphic = true;
 // add to graphics layer
 this._gl.add(graphic);
 // get current features
 var features = isMapClicked ? this.map.infoWindow.features : [];
 // remove existing geoform graphic(s)
 var filtered = array.filter(features, function (item) {
 return !item._geoformGraphic;
 // add feature
 filtered.splice(0, 0, graphic);
 // set popup features
 this.map.infoWindow.setFeatures(filtered);
 // show popup
 this.map.infoWindow.show(graphic.geometry);
 // edit movable
 this.editToolbar.activate(editToolbar.MOVE, graphic, null);
 return true;
 _setCoordInputs: function (pt) {
 // get lat/lng
 var lat = pt.getLatitude();
 var lng = pt.getLongitude();
 // if valid lat/lng
 if (typeof lat !== "undefined" && typeof lng !== "undefined") {
 dom.byId('lat_coord').value = lat.toFixed(5);
 dom.byId('lng_coord').value = lng.toFixed(5);
 // try to convert LL to other coordinates
 try {
 // set USNG
 var usngResult = usng.LLtoUSNG(lat, lng, 5);
 if (usngResult) {
 dom.byId('usng_coord').value = usngResult;
 // set MGRS
 var mgrsResult = usng.LLtoMGRS(lat, lng, 5);
 if (mgrsResult) {
 dom.byId('mgrs_coord').value = mgrsResult;
 // set UTM
 var utmResults = [];
 usng.LLtoUTM(lat, lng, utmResults);
 if (utmResults && utmResults.length === 3) {
 var northing = parseFloat(utmResults[1]);
 var easting = parseFloat(utmResults[0]);
 var zone = parseInt(utmResults[2], 10);
 if(northing < 0){
 zone += "S";
 northing = northing + NORTHING_OFFSET;
 else{
 zone += "N";
 dom.byId('utm_easting').value = parseInt(easting, 10);
 dom.byId('utm_northing').value = parseInt(northing, 10);
 dom.byId('utm_zone_number').value = zone;
 } catch (e) {
 console.log(e);
 this._checkUTM();
 this._checkMGRS();
 this._checkLatLng();
 this._checkUSNG();
 // create lat lon point
 _calculateLatLong: function (pt) {
 // return string
 var str = '';
 // if spatial ref is web mercator
 if (pt) {
 // get lat/lng
 if (lat && lng) {
 // create string
 str = nls.user.latitude + ': ' + lat.toFixed(5) + ', ' + ' ' + nls.user.longitude + ': ' + lng.toFixed(5);
 return str;
 //function to set the logo-path, application title and details
 _setAppConfigurations: function (appConfigurations) {
 var appLogoNode, appTitleNode, appDescNode;
 // get all nodes
 appLogoNode = dom.byId('appLogo');
 appTitleNode = dom.byId('appTitle');
 appDescNode = dom.byId('appDescription');
 // set logo
 if (appConfigurations.Logo && !this.config.disableLogo) {
 appLogoNode.src = appConfigurations.Logo;
 } else {
 domClass.add(appLogoNode, "hide");
 // set title
 if (appConfigurations.Title) {
 appTitleNode.innerHTML = appConfigurations.Title;
 } else {
 domClass.add(appTitleNode, "hide");
 // set description
 if (appConfigurations.Description) {
 appDescNode.innerHTML = appConfigurations.Description;
 } else {
 domClass.add(appDescNode, "hide");
 // remove jumbotron style option
 if (domClass.contains(appLogoNode, "hide") && domClass.contains(appTitleNode, "hide") && domClass.contains(appDescNode, "hide")) {
 domClass.add(dom.byId('jumbotronNode'), "hide");
 //function to set the theme for application
 _switchStyle: function (themeName) {
 if (themeName == currentTheme.id && currentTheme.url) {
 var themeNode = domConstruct.create("link", {
 rel: "stylesheet",
 type: "text/css",
 domConstruct.place(themeNode, query("head")[0]);
 // add identifying theme class to the body
 domClass.add(document.body, "geoform-" + currentTheme.id);
 //function to validate and create the form
 _createForm: function (fields) {
 // editable layer
 if (this._formLayer) {
 // if indexedDB is supported
 if (window.indexedDB && this.config.enableOfflineSupport) {
 // get offline support
 require(["application/OfflineSupport"], lang.hitch(this, function (OfflineSupport) {
 // support basic offline editing
 this._offlineSupport = new OfflineSupport({
 map: this.map,
 proxy: this.config.proxyurl,
 layer: this._formLayer
 domConstruct.empty(dom.byId('userForm'));
 this.sortedFields = [];
 var formContent, labelContent, matchingField, newAddedFields = [],
 userFormNode;
 if (!this._formLayer) {
 this._showErrorMessageDiv(nls.user.noLayerConfiguredMessage, dom.byId("errorMessageDiv"));
 array.some(query(".row"), lang.hitch(this, function (currentNode) {
 if (currentNode.children) {
 if (domClass.contains(currentNode.children[0], "errorMessageDiv")) {
 array.forEach(query(currentNode).nextAll(), lang.hitch(this, function (currentNode) {
 domStyle.set(currentNode, "display", "none");
 return true;
 return;
 array.forEach(this._formLayer.fields, lang.hitch(this, function (field) {
 var layerField = lang.clone(field);
 matchingField = false;
 array.forEach(fields, lang.hitch(this, function (currentField) {
 if (layerField.name == currentField.name && currentField.visible) {
 if (layerField.name === this._formLayer.typeIdField) {
 layerField.subTypes = this._formLayer.types;
 layerField.typeField = true;
 } else {
 layerField.typeField = false;
 newAddedFields.push(lang.mixin(layerField, currentField));
 matchingField = true;
 } else if (layerField.name == currentField.name && currentField.hasOwnProperty("visible") && !currentField.visible) {
 if (!matchingField) {
 if ((layerField.editable && !(layerField.type === "esriFieldTypeOID" || layerField.type === "esriFieldTypeGeometry" || layerField.type === "esriFieldTypeBlob" || layerField.type === "esriFieldTypeRaster" || layerField.type === "esriFieldTypeGUID" || layerField.type === "esriFieldTypeGlobalID" || layerField.type === "esriFieldTypeXML"))) {
 } else {
 layerField.isNewField = true;
 newAddedFields.push(layerField);
 array.forEach(fields, lang.hitch(this, function (sortedElement) {
 array.some(newAddedFields, lang.hitch(this, function (newElement) {
 var fName = newElement.name;
 if (this.config.appid) {
 if (sortedElement.name == fName) {
 this.sortedFields.push(newElement);
 return true;
 } else {
 return true;
 array.forEach(this.sortedFields, lang.hitch(this, function (currentField, index) {
 //code to set true/false value to property 'isTypeDependent' of the field.
 currentField.isTypeDependent = false;
 array.forEach(this._formLayer.types, function (type) {
 var currentType = lang.clone(type);
 var hasDomainValue = null,
 hasDefaultValue = null;
 hasDomainValue = currentType.domains[currentField.name];
 hasDefaultValue = currentType.templates[0].prototype.attributes[currentField.name];
 //if hasDefaultValue is 0 then we need to set isTypeDependent property to true
 if (hasDefaultValue === 0) {
 hasDefaultValue = true;
 if ((hasDomainValue && hasDomainValue.type !== "inherited") || (hasDefaultValue && !currentField.typeField)) {
 currentField.isTypeDependent = true;
 if (currentField.isTypeDependent) {
 return true;
 //function to create form elements(referenceNode is passed null)
 this._createFormElements(currentField, index, null);
 // if form has attachments
 if (this._formLayer.hasAttachments && this.config.attachmentInfo[this._formLayer.id] && this.config.attachmentInfo[this._formLayer.id].enableAttachments) {
 var requireField = null,
 helpBlock, labelHTML = "",
 divRow, divColumn1, fileBtnSpan, fileInput, fileChange, divColumn2, fileForm;
 userFormNode = dom.byId('userForm');
 formContent = domConstruct.create("div", {
 className: "form-group hasAttachment geoFormQuestionare"
 }, userFormNode);
 //code to make the attachment input mandatory
 if (this.config.attachmentInfo[this._formLayer.id].attachmentIsRequired) {
 domClass.add(formContent, "mandatory");
 requireField = domConstruct.create("small", {
 className: 'requireFieldStyle',
 innerHTML: nls.user.requiredField
 }, formContent);
 // attachment label html
 labelHTML += "<span class=\"glyphicon glyphicon-paperclip\"></span> ";
 labelHTML += (this.config.attachmentInfo[this._formLayer.id].attachmentLabel || nls.user.attachment);
 // attachment label
 labelContent = domConstruct.create("label", {
 innerHTML: labelHTML,
 "for": "geoFormAttachment"
 }, formContent);
 if (requireField && labelContent) {
 domConstruct.place(requireField, labelContent, "last");
 divRow = domConstruct.create("div", {
 "class": "row"
 }, formContent);
 divColumn1 = domConstruct.create("div", {
 "class": "col-sm-2 form-group"
 }, divRow);
 fileBtnSpan = domConstruct.create("span", {
 "class": "btn btn-default btn-file",
 "innerHTML": nls.user.btnSelectFileText
 }, divColumn1);
 fileForm = domConstruct.create("form", {
 "class": "selectFileForm"
 }, fileBtnSpan);
 fileInput = domConstruct.create("input", {
 "type": "file",
 "class": "hideFileInputUI",
 "title": nls.user.selectFileTitle,
 "name": "attachment"
 }, fileForm);
 fileChange = on(fileInput, "change", lang.hitch(this, function (evt) {
 this._validateSelectedFile(evt, fileInput, fileBtnSpan, formContent, fileChange);
 fileInput.setAttribute("aria-required", true);
 fileInput.setAttribute("required", "");
 if (this.config.attachmentInfo[this._formLayer.id].attachmentHelpText) {
 helpBlock = domConstruct.create("p", {
 className: "help-block",
 innerHTML: this.config.attachmentInfo[this._formLayer.id].attachmentHelpText
 }, formContent);
 //prepare domnode to show the selected file list
 divColumn2 = domConstruct.create("div", {
 "class": "col-sm-10",
 "id": "divColumn2"
 }, divRow);
 // randomblink : add in piece that creates the events and listeners
 // make sure this is performed at end of all Form Element creation
 this._createSubscribersList();
 this._verifyHumanEntry();
 // BLINKS CODE: Create the list of Subscribers.
 _createSubscribersList: function(){
 this.subscriptions = array.map( this.subscriptions, lang.hitch( this, function( currSubscriber ){
 var currPublishers = array.map( currSubscriber.subscription, lang.hitch( this, function( currPublisher ){
 array.forEach( currPublisher.editorFields, lang.hitch( this, function( editorField ){
 this._createTopicPublisher( editorField );
 return {
 "publication": currPublisher.publication,
 "editorFields": currPublisher.editorFields,
 "requiredFields": currPublisher.required
 this. _createTopicSubscriber( currSubscriber.name );
 return { "subscriber": currSubscriber.name, "subscription": currPublishers };
 // BLINKS CODE: Let's consume the publication as it's published.
 _consumePublication: function( nameOfSubscriber ){
 var targetSubscriber;
 array.forEach( this.subscriptions, lang.hitch( this, function( currSubscriber ){
 if( currSubscriber.subscriber === nameOfSubscriber ){
 targetSubscriber = currSubscriber;
 var targetSubscription;
 if( array.some( targetSubscriber.subscription, lang.hitch( this, function( currSubscription )
 var AllReqsMet = this._isRequirementsMet( currSubscription.requiredFields );
 targetSubscription = currSubscription;
 return AllReqsMet;
 // If AllReqsMet returns TRUE then do this
 var listOfFields = targetSubscription.editorFields;
 var targetPublication = targetSubscription.publication;
 listOfFields = array.map( listOfFields, lang.hitch( this, function( currField ){
 var currTargetField = dom.byId( currField );
 var currTargetFieldValue;
 switch( currTargetField.nodeName )
 case "INPUT": currTargetFieldValue = currTargetField.value; break;
 case "SELECT":
 if( currTargetField.selectedOptions[0].value !== "" ){
 currTargetFieldValue = currTargetField.selectedOptions[0].text;
 }else{
 currTargetFieldValue = currTargetField.selectedOptions[0].value;
 break;
 return { "value": currTargetFieldValue };
 var testPublish = string.substitute( targetPublication, listOfFields );
 dom.byId( nameOfSubscriber ).value = testPublish;
 // BLINKS CODE: Let's check if the Requirements are met.
 _isRequirementsMet: function( requirementsArray ){
 if( requirementsArray.length === 0 ){
 return true;
 if( array.every( requirementsArray, lang.hitch( this, function( requiredFieldName ){
 var targetField = dom.byId( requiredFieldName ), valueToTest = "";
 switch( targetField.nodeName ){
 case "INPUT": valueToTest = targetField.value; break;
 case "SELECT":
 if( targetField.selectedOptions[0].value !== "" ){
 valueToTest = targetField.selectedOptions[0].text;
 }else{
 valueToTest = targetField.selectedOptions[0].value;
 break;
 default: break;
 return valueToTest !== "";
 return true;
 }else{
 return false;
 // BLINKS CODE: This takes the name of the field that is subscribing to the publication and sets up the Subscribe command
 _createTopicSubscriber: function( subscriberName ){
topic.subscribe( "publishTopic", lang.hitch( this, function( ){
 this._consumePublication( subscriberName, arguments[0].publisherName, arguments[0].publishedValue );
 // BLINKS CODE: This takes the name of the field that will be publishing it's data and sets up the Publish command
 _createTopicPublisher: function( publisherName ){
 var newPublisherField = dom.byId( publisherName ), publisherFieldType = newPublisherField.nodeName, fieldEvent = "N/A", publisherValue;
 switch( publisherFieldType )
 case "INPUT": fieldEvent = "keyup"; publisherValue = newPublisherField.value; break;
 case "SELECT": fieldEvent = "change"; publisherValue = newPublisherField.selectedOptions[0].text; break;
 on( newPublisherField, fieldEvent, function(){
 case "INPUT": publisherValue = newPublisherField.value; break;
 case "SELECT":
 if( newPublisherField.selectedOptions[0].value !== "" ){
 }else{
 publisherValue = newPublisherField.selectedOptions[0].value;
 break;
 topic.publish( "publishTopic", { "publisherName": publisherName, "publishedValue": publisherValue } );
 _addToFileList: function (fileInput, fileBtnSpan, formContent, fileDetails) {
 var unit, fileSize = "",
 alertHtml, fileChange, fileForm, formsToSubmit, formId;
 formsToSubmit = query(".formToSubmit", dom.byId('userForm'));
 //Toggle class and give unique id to the form selected for attachment
 domClass.replace(fileInput.parentNode, "formToSubmit", "selectFileForm");
 if (formsToSubmit.length === 0) {
 formId = 0;
 } else {
 formId = parseInt(formsToSubmit[formsToSubmit.length - 1].id.split("formToSubmit")[1]) + 1;
 fileInput.parentNode.id = "formToSubmit" + formId;
 domClass.replace(fileInput, "fileToSubmit", "hideFileInputUI");
 fileInput.id = "geoformAttachment" + formId;
 //disabling and hiding the selected file so that it is neither clickable nor visible
 //need to re-enable the file before submitting
 domAttr.set(fileInput, "disabled", "disabled");
 domStyle.set(fileInput, "opacity", "0");
 domStyle.set(fileInput, "position", "absolute");
 //check for availability of HTML-5 file handling properties and then display the file size on domNode
 if (fileDetails.files && fileDetails.files[0]) {
 fileSize = parseFloat(fileDetails.files[0].size / 1024);
 unit = "kb";
 if (fileSize > 999) {
 unit = "mb";
 fileSize = parseFloat(fileSize / 1024);
 fileSize = fileSize.toFixed(2) + unit;
 //Preparing the domNode for selected file
 alertHtml = "<div class=\"alert alert-dismissable alert-success\">";
 alertHtml += "<button type=\"button\" class=\"close\" data-dismiss=\"alert\">" + "×" + "</button>";
 alertHtml += "<strong class=\"fileInputUI\">" + fileDetails.value.split('\\').pop() + "<br/>" + fileSize + "</strong>";
 alertHtml += "</div>";
 alertHtml = domConstruct.place(alertHtml, dom.byId("divColumn2"), "last");
 domConstruct.place(fileInput.parentNode, alertHtml, "last");
 //binding event to perform activities on removal of a selected file from the file list
 on(query(".close", alertHtml)[0], a11yclick, function () {
 if (query(".alert-dismissable").length === 1) {
 domClass.remove(formContent, ".has-success");
 fileInput = "";
 }, fileBtnSpan);
 "type": "file",
 }, fileForm);
 domConstruct.place(fileForm, fileBtnSpan, "first");
 _validateSelectedFile: function (evt, fileInput, fileBtnSpan, formContent, fileChange) {
 fileChange.remove();
 if (evt.currentTarget.files && evt.currentTarget.files[0] && evt.currentTarget.files[0].size > 26214400) {
 $(fileBtnSpan).popover({
 content: nls.user.fileTooLargeError,
 container: 'body',
 trigger: 'manual',
 placement: 'bottom'
 $(fileBtnSpan).popover('show');
 setTimeout(function () {
 $(fileBtnSpan).popover('hide');
 }, 3000);
 //this line to change the value of fileinput so that on-change event fires
 $(evt.currentTarget).replaceWith($(evt.currentTarget).val('').clone(true));
 fileChange = on(query(".hideFileInputUI")[0], "change", lang.hitch(this, function (evt) {
 return true;
 if (query(".alert-dismissable", dom.byId("divColumn2")).length > 19) {
 content: nls.user.exceededFileCountError,
 container: 'body',
 trigger: 'manual',
 placement: 'bottom'
 }, 3000);
 return true;
 //block to remove error message after selection of file and to replace error class with success class.
 if (query(".errorMessage", formContent)[0]) {
 this._removeErrorNode(query(".errorMessage", formContent)[0]);
 domClass.replace(formContent, "has-success", "has-error");
 this._addToFileList(query(".hideFileInputUI")[0], fileBtnSpan, formContent, evt.currentTarget);
 //function to create elements of form.
 _createFormElements: function (field, index, referenceNode) {
 var currentField = lang.clone(field);
 var radioContainer, fieldname, radioContent, inputContent, labelContent, fieldLabelText, selectOptions, inputLabel, radioInput, formContent, requireField, userFormNode,
 checkboxContainer, checkboxContent, checkBoxCounter = 0,
 helpBlock, rangeHelpText, inputGroupContainer;
 formContent = domConstruct.create("div", {}, userFormNode);
 if (!!currentField.locked) {
 domClass.add(formContent, "disabled");
 // randomblink : Beginning of code for concantenated field
 if (!!currentField.subscription)
 domClass.add(formContent, "subscriber");
 this.subscriptions.push(currentField);
 // randomblink : End of code for concantenated field
//code block to fade in the sub-types dependent fields
 if (referenceNode) {
 domConstruct.place(formContent, referenceNode, "after");
 domClass.add(formContent, "fade");
 domClass.add(formContent, "in");
 }, 100);
 if ((!currentField.nullable || currentField.typeField) && currentField.displayType !== "checkbox") {
 domClass.add(formContent, "form-group geoFormQuestionare mandatory");
 }, formContent);
 } else {
 domClass.add(formContent, "form-group geoFormQuestionare");
 if (currentField.alias) {
 fieldLabelText = currentField.alias;
 } else {
 fieldLabelText = currentField.name;
 fieldname = currentField.name;
 if (currentField.displayType !== "checkbox" || currentField.domain) {
 "for": fieldname,
 className: "control-label",
 innerHTML: fieldLabelText,
 id: fieldname + "_label_" + index
 }, formContent);
 if (this._formLayer.templates[0] && !currentField.defaultValue) {
 for (var fieldAttribute in this._formLayer.templates[0].prototype.attributes) {
 if (fieldAttribute.toLowerCase() == fieldname.toLowerCase()) {
 currentField.defaultValue = this._formLayer.templates[0].prototype.attributes[fieldAttribute];
 //code to make select boxes in case of a coded value
 if (currentField.domain || currentField.typeField) {
 if ((currentField.domain && (typeof currentField.domain.type === 'undefined' || currentField.domain.type === 'codedValue')) || currentField.typeField) {
 radioInput = false;
 if (currentField.displayType && currentField.displayType === "radio") {
 radioInput = true;
 //check for fieldType: if not present create dropdown
 //If present check for fieldType value and accordingly populate the control
 if (!radioInput) {
 inputContent = domConstruct.create("select", {
 className: "selectDomain",
 disabled: !!currentField.locked,
 "id": fieldname
 }, formContent);
 if (currentField.domain && !currentField.typeField) {
 if (currentField.displayType == "Filter Select") {
 this._createFilterSelectInput(inputContent, fieldname);
 } else {
 selectOptions = domConstruct.create("option", {
 innerHTML: nls.user.domainDefaultText,
 value: ""
 }, inputContent);
 domClass.add(inputContent, "form-control");
 array.forEach(currentField.domain.codedValues, lang.hitch(this, function (currentOption) {
 innerHTML: currentOption.name,
 value: currentOption.code
 }, inputContent);
 //if field contain default value, make that option selected
 if (currentField.defaultValue === currentOption.code) {
 domAttr.set(selectOptions, "selected", true);
 domClass.add(inputContent.parentNode, "has-success");
 if (domClass.contains(inputContent, "filterSelect")) {
 $(inputContent).val(currentOption.code).trigger("change");
 } else {
 } else {
 value: ""
 }, inputContent);
 if(currentField.domain){
 selectOptions = domConstruct.create("option", {}, inputContent);
 selectOptions.text = currentOption.name;
 selectOptions.value = currentOption.code;
 //default values for subtypes(if any) has to be handled here
 else if(currentField.subTypes){
 array.forEach(currentField.subTypes, lang.hitch(this, function (currentOption) {
 selectOptions.value = currentOption.id;
 on($("#" + fieldname), "change", lang.hitch(this, function (evt) {
 //function call to take appropriate actions on selection of a subtypes
 if (currentField.typeField) {
 this._validateTypeFields(evt.currentTarget, currentField);
 //To apply has-success class on selection of a valid option
 if (evt.target.value !== "") {
 if (query(".errorMessage", evt.currentTarget.parentNode).length !== 0) {
 domConstruct.destroy(query(".errorMessage", evt.currentTarget.parentNode)[0]);
 domClass.remove($(evt.target.parentNode)[0], "has-error");
 domClass.add($(evt.target.parentNode)[0], "has-success");
 } else {
 domClass.remove($(evt.target.parentNode)[0], "has-success");
 } else {
 radioContainer = domConstruct.create("div", {
 className: "radioContainer",
 }, formContent);
 radioContent = domConstruct.create("div", {
 className: "radio"
 }, radioContainer);
 inputLabel = domConstruct.create("label", {
 "for": fieldname + currentOption.code
 }, radioContent);
 inputContent = domConstruct.create("input", {
 "id": fieldname + currentOption.code,
 className: "radioInput",
 type: "radio",
 }, inputLabel);
 //if field has default value,set radio button checked by default
 if (currentOption.code === currentField.defaultValue) {
 domAttr.set(inputContent, "checked", "checked");
 domClass.add(radioContainer.parentNode, "has-success");
 // add text after input
 inputLabel.innerHTML += currentOption.name;
 //code to assign has-success class on click of a radio button
 on(inputContent, a11yclick, function (evt) {
 if (evt.target.checked) {
 if (query(".errorMessage", formContent).length !== 0) {
 domConstruct.destroy(query(".errorMessage", formContent)[0]);
 domClass.remove(formContent, "has-error");
 domClass.add(formContent, "has-success");
 } else {
 domClass.remove(formContent, "has-success");
 } else {
 //Code to validate for applying has-success class
 className: "radio"
 }, radioContainer);
 "for": fieldname + currentOption.id
 }, radioContent);
 "id": fieldname + currentOption.id,
 type: "radio",
 value: currentOption.id
 }, inputLabel);
 if (currentOption.id === currentField.defaultValue) {
 on(dom.byId(fieldname + currentOption.id), a11yclick, lang.hitch(this, function (evt) {
 } else {
 } else {
 //if field type is date
 if (currentField.type == "esriFieldTypeDate") {
 var inputRangeDateGroupContainer = this._addNotationIcon(formContent, "glyphicon-calendar");
 inputContent = this._createDateField(inputRangeDateGroupContainer, true, fieldname, currentField, currentField.defaultValue);
 if(currentField.domain.minValue !== currentField.domain.maxValue && currentField.domain.minValue > -2147483648 && currentField.domain.maxValue > -2147483648){
 rangeHelpText = string.substitute(nls.user.dateRangeHintMessage, {
 minValue: moment(currentField.domain.minValue).format(this.dateFormat),
 maxValue: moment(currentField.domain.maxValue).format(this.dateFormat),
 openStrong: "<strong>",
 closeStrong: "</strong>"
 } else {
 //if field type is integer
 rangeHelpText = this._setRangeForm(currentField, formContent, fieldname);
 } else {
 //Condition to check if a checkbox is required for integer fields in user form
 if (currentField.displayType && currentField.displayType === "checkbox") {
 currentField.type = "binaryInteger";
 switch (currentField.type) {
 case "esriFieldTypeString":
 if (currentField.displayType && currentField.displayType === "textarea") {
 inputContent = domConstruct.create("textarea", {
 className: "form-control",
 "data-input-type": "String",
 "rows": 4,
 "maxLength": currentField.length,
 "id": fieldname
 }, formContent);
 } else {
 if (currentField.displayType && currentField.displayType === "email") {
 inputGroupContainer = this._addNotationIcon(formContent, "glyphicon-envelope");
 } else if (currentField.displayType && currentField.displayType === "url") {
 inputGroupContainer = this._addNotationIcon(formContent, "glyphicon-link");
 type: "text",
 "id": fieldname
 }, inputGroupContainer ? inputGroupContainer : formContent);
 break;
 case "binaryInteger":
 checkboxContainer = domConstruct.create("div", {
 className: "checkboxContainer"
 }, formContent);
checkboxContent = domConstruct.create("div", {
 className: "checkbox"
 }, checkboxContainer);
 "for": fieldname
 }, checkboxContent);
 className: "checkboxInput",
 type: "checkbox",
 "data-input-type": "binaryInteger",
 "id": fieldname
 }, inputLabel);
 domAttr.set(inputContent, "data-checkbox-index", checkBoxCounter);
 inputLabel.innerHTML += fieldLabelText;
 checkBoxCounter++;
 break;
 case "esriFieldTypeSmallInteger":
 type: "text",
 "data-input-type": "SmallInteger",
 "id": fieldname,
 "pattern": "[0-9]*"
 }, formContent);
 break;
 case "esriFieldTypeInteger":
 type: "text",
 "data-input-type": "Integer",
 "id": fieldname,
 "pattern": "[0-9]*"
 }, formContent);
 break;
 case "esriFieldTypeSingle":
 type: "text",
 "data-input-type": "Single",
 "id": fieldname
 }, formContent);
 break;
 case "esriFieldTypeDouble":
 type: "text",
 "data-input-type": "Double",
 "id": fieldname,
 step: ".1"
 }, formContent);
 break;
 case "esriFieldTypeDate":
 var inputDateGroupContainer = this._addNotationIcon(formContent, "glyphicon-calendar");
 if (currentField.hiddenDate) {
 domClass.add(formContent, "hidden");
 inputContent = this._createDateField(inputDateGroupContainer, false, fieldname, currentField, currentField.defaultValue);
 break;
 //Add Placeholder if present
 if (currentField.tooltip) {
 domAttr.set(inputContent, "placeholder", currentField.tooltip);
 //If present fetch default values
 if (currentField.defaultValue) {
 if (currentField.type == "esriFieldTypeString" && lang.trim(currentField.defaultValue) !== "") {
 domAttr.set(inputContent, "value", currentField.defaultValue);
 //Add specific display type if present
 if (currentField.displayType && currentField.displayType !== "") {
 domAttr.set(inputContent, "data-display-type", currentField.displayType);
 var helpHTML = "";
 if (currentField.type !== "esriFieldTypeDate") {
 on(inputContent, "focusout", lang.hitch(this, function (evt) {
 this._validateField(evt, true);
 on(inputContent, "keyup", lang.hitch(this, function () {
 if (currentField.displayType === "textarea") {
 var availableLength;
 if (inputContent.value.length > currentField.length) {
 //Work around to make textarea work in IE8
 //Truncate the text if necessary
 $(inputContent).val(inputContent.value.substr(0, currentField.length));
 } else {
 availableLength = string.substitute(nls.user.remainingCharactersHintMessage, {
 value: (currentField.length - inputContent.value.length).toString()
 helpBlock.innerHTML = lang.trim(helpHTML + " " + availableLength);
 // if field is required and field exists
 if (!currentField.nullable && inputContent) {
 inputContent.setAttribute("aria-required", true);
 inputContent.setAttribute("required", "");
 if(currentField.defaultValue){
 // store default value
 domAttr.set(inputContent, "data-default-value", currentField.defaultValue);
 if (currentField.isNewField) {
 // make sure popup info and fields are defined
 if (this._formLayer && this._formLayer.infoTemplate && this._formLayer.infoTemplate.info && this._formLayer.infoTemplate.info.fieldInfos) {
 array.forEach(this._formLayer.infoTemplate.info.fieldInfos, function (currentFieldPopupInfo) {
 if (currentFieldPopupInfo.fieldName == currentField.name) {
 if (currentFieldPopupInfo.tooltip) {
 helpHTML = currentFieldPopupInfo.tooltip;
 } else {
 helpHTML = currentField.fieldDescription;
 if (helpHTML || currentField.displayType === "textarea") {
 var availableLength = "";
 value: currentField.length.toString()
 innerHTML: lang.trim(helpHTML + " " + availableLength)
 }, formContent);
 if (rangeHelpText) {
 var options = {
 trigger: 'focus',
 placement: 'top',
 container: 'body',
 content: rangeHelpText,
 html: true
 $('#' + fieldname).popover(options);
 // date range field
 _setRangeForm: function (currentField, formContent, fieldname) {
 var inputContent, setStep, setDefault = "",
 stepDivisibility = 'none',
 decimalPoints = 0,
 inputcontentSpinner, rangeHelpText;
 type: "text",
 min: currentField.domain.minValue.toString(),
 max: currentField.domain.maxValue.toString()
 }, formContent);
 domAttr.set(inputContent, "data-input-type", currentField.type.replace("esriFieldType", ""));
 setDefault = currentField.defaultValue;
 if (domAttr.get(inputContent, "data-input-type") === "Double" || domAttr.get(inputContent, "data-input-type") === "Single") {
 decimalPoints = 2;
 if (currentField.domain.minValue - Math.floor(currentField.domain.minValue) === 0.5) {
 setStep = 0.5;
 } else {
 setStep = 0.1;
 } else {
 setStep = 1;
 stepDivisibility = 'round';
 inputcontentSpinner = $(inputContent).TouchSpin({
 initval: setDefault,
 max: currentField.domain.maxValue.toString(),
 forcestepdivisibility: stepDivisibility,
 step: setStep,
 boostat: 5,
 decimals: decimalPoints,
 maxboostedstep: 10
 //Event to address validations for manual entry in the touch-spinner input.
 on(inputContent, "keyup", function () {
 if (inputContent.value === "") {
 domClass.remove(inputContent.parentNode.parentNode, "has-success");
 } else {
 domClass.add(inputContent.parentNode.parentNode, "has-success");
 on(inputcontentSpinner, "touchspin.on.startspin", lang.hitch(this, function (evt) {
 inputcontentSpinner.trigger("touchspin.updatesettings", {});
 domClass.add(evt.currentTarget.parentNode.parentNode, "has-success");
 if (!currentField.nullable) {
 rangeHelpText = string.substitute(nls.user.textRangeHintMessage, {
 minValue: currentField.domain.minValue.toString(),
 maxValue: currentField.domain.maxValue.toString(),
 return rangeHelpText;
 _createFilterSelectInput: function (inputContent, fieldname) {
 domClass.add(inputContent, "filterSelect");
 domStyle.set(inputContent, "width", "100%");
 var options = domConstruct.create("option", {}, inputContent);
 options.text = "";
 options.value = "";
 $("#" + fieldname).select2({
 placeholder: nls.user.filterSelectEmptyText,
 allowClear: true
 //function to validate the fields defined within subtypes
 _validateTypeFields: function (currentTarget, currentField) {
 var selectedType, defaultValue, switchDomainType, referenceNode;
 if (currentTarget.value === "") {
 //no type is selected, so the code to remove the type dependent fields will come here
 array.forEach(this.sortedFields, lang.hitch(this, function (currentInput) {
 if (!currentInput.isTypeDependent) {
 return true;
 if (dom.byId(currentInput.name)) {
 var domToDestroy = this._getFormElement(dom.byId(currentInput.name));
 domConstruct.destroy(domToDestroy);
 this._resizeMap();
 return true;
 } else {
 //code to get all the domains and default values of the selected subtype
 array.some(currentField.subTypes, function (currentSelection) {
 if (currentTarget.value === currentSelection.id.toString()) {
 selectedType = currentSelection;
 return true;
 //initial point of reference to put elements
 referenceNode = dom.byId(this._formLayer.typeIdField).parentNode;
 //code to populate type dependent fields
 array.forEach(this.sortedFields, lang.hitch(this, function (currentInput, index) {
 var field = null,
 domain, minValue, maxValue;
 //condition to filter out fields independent of subtypes
 return true;
 array.some(this._formLayer.fields, function (layerField) {
 var lyrField = lang.clone(layerField);
 if (lyrField.name === currentInput.name) {
 field = lang.clone(lang.mixin(lyrField, currentInput));
 return true;
 //code to fetch the default value of a field for selected subtype.
 if (selectedType.templates[0]) {
 for (var fieldAttribute in selectedType.templates[0].prototype.attributes) {
 if (fieldAttribute.toLowerCase() === field.name.toLowerCase()) {
 defaultValue = selectedType.templates[0].prototype.attributes[fieldAttribute];
 field.defaultValue = defaultValue;
 domAttr.set(currentTarget, "data-default-value", defaultValue);
 break;
 for (var i in selectedType.domains) {
 //condition to find the domain properties for current field
 if (i === field.name) {
 switchDomainType = selectedType.domains[i].type || "codedValue";
 switch (switchDomainType) {
 case "inherited":
 //for inherited domains we need to populate the domains from the layer.
 if (field.domain.type === "range") {
 minValue = field.domain.minValue;
 maxValue = field.domain.maxValue;
 } else {
 domain = field.domain.codedValues;
 break;
 case "codedValue":
 if (!field.domain) {
 field.domain = {};
 field.domain.codedValues = selectedType.domains[i].codedValues;
 domain = selectedType.domains[i].codedValues;
 break;
 case "range":
 //Condition to change the range domain values of field already having domain.
 field.domain = {};
 field.domain.minValue = selectedType.domains[i].minValue;
 field.domain.maxValue = selectedType.domains[i].maxValue;
 break;
 //code to be executed when the input is already present
 if (dom.byId(field.name)) {
 var domToDestroy;
 domToDestroy = this._getFormElement(dom.byId(field.name));
 this._createFormElements(field, index, referenceNode);
 referenceNode = this._getFormElement(dom.byId(field.name));
 this._resizeMap();
 // validate form field
 _validateField: function (currentNode, iskeyPress) {
 var inputType, inputValue, displayType = null,
 node, typeCastedInputValue, decimal = /^[-+]?[0-9]+$/,
 float = /^[-+]?[0-9]+\.[0-9]+$/,
 email = /[a-z0-9!#$%&'*+/=?^_`{|}~-]+(?:\.[a-z0-9!#$%&'*+/=?^_`{|}~-]+)*@(?:[a-z0-9](?:[a-z0-9-]*[a-z0-9])?\.)+[a-z0-9](?:[a-z0-9-]*[a-z0-9])?/,
 url = /^(http?:\/\/){0,1}(www\.){0,1}[a-zA-Z0-9\.\-]+\.[a-zA-Z]{2,5}[\.]{0,1}/,
 error;
 //To remove extra spaces
 currentNode.currentTarget.value = lang.trim(currentNode.currentTarget.value);
 if (iskeyPress) {
 inputValue = currentNode.currentTarget.value;
 inputType = domAttr.get(currentNode.currentTarget, "data-input-type");
 if (domAttr.get(currentNode.currentTarget, "data-display-type") !== null) {
 displayType = domAttr.get(currentNode.currentTarget, "data-display-type");
 //Since we are adding a new div inside formContent in case of email and url
 //We need to traverse one step more
 if (displayType === "email" || displayType === "url") {
 node = $(currentNode.target.parentNode.parentNode)[0];
 } else {
 if ($(currentNode.target)) {
 node = $(currentNode.target.parentNode)[0];
 } else {
 node = $(currentNode.srcElement.parentNode)[0];
 } else {
 inputValue = query(".form-control", currentNode)[0].value;
 inputType = domAttr.get(query(".form-control", currentNode)[0], "data-input-type");
 if (domAttr.get(query(".form-control", currentNode)[0], "data-display-type") !== null) {
 displayType = domAttr.get(query(".form-control", currentNode)[0], "data-display-type");
 node = query(".form-control", currentNode)[0].parentElement;
 switch (inputType) {
 case "String":
 if (inputValue.length !== 0 && ((displayType === "email" && inputValue.match(email)) || (displayType === "url" && inputValue.match(url)) || displayType === null) || displayType === "text" || displayType === "textarea") {
 this._validateUserInput(false, node, inputValue, iskeyPress);
 } else {
 error = string.substitute(nls.user.invalidString, {
 this._validateUserInput(error, node, inputValue, iskeyPress);
 break;
 case "SmallInteger":
 typeCastedInputValue = parseInt(inputValue);
 if ((inputValue.match(decimal) && typeCastedInputValue >= -32768 && typeCastedInputValue <= 32767) && inputValue.length !== 0) {
 this._validateUserInput(false, node, inputValue);
 } else {
 error = string.substitute(nls.user.invalidSmallNumber, {
 break;
 case "Integer":
 if ((inputValue.match(decimal) && typeCastedInputValue >= -2147483648 && typeCastedInputValue <= 2147483647) && inputValue.length !== 0) {
 } else {
 error = string.substitute(nls.user.invalidNumber, {
 break;
 case "Single":
 //zero or more occurrence of (+-) at the start of expression
 //at least one occurrence of digits between o-9
 //occurrence of .
 //at least one occurrence of digits between o-9 in the end
 typeCastedInputValue = parseFloat(inputValue);
 if (((inputValue.match(decimal) || inputValue.match(float)) && typeCastedInputValue >= -3.4 * Math.pow(10, 38) && typeCastedInputValue <= 1.2 * Math.pow(10, 38)) && inputValue.length !== 0) {
 } else {
 error = string.substitute(nls.user.invalidFloat, {
 break;
 case "Double":
 if (((inputValue.match(decimal) || inputValue.match(float)) && typeCastedInputValue >= -2.2 * Math.pow(10, 308) && typeCastedInputValue <= 1.8 * Math.pow(10, 38)) && inputValue.length !== 0) {
 } else {
 error = string.substitute(nls.user.invalidDouble, {
 break;
 // reset form fields
 _clearFormFields: function () {
 this._createForm(this._savedFields);
 // validate form input
 _validateUserInput: function (error, node, inputValue, iskeyPress) {
 if (domClass.contains(node, "filterSelect") && inputValue === "" && domClass.contains(node.parentElement, "mandatory")) {
 this._showErrorMessageDiv(error, node.parentElement.children[0]);
 domClass.add(node.parentElement, "has-error");
 domClass.remove(node, "has-success");
 return;
 if (query(".errorMessage", node)[0]) {
 domConstruct.destroy(query(".errorMessage", node)[0]);
 if (!error || (inputValue.length === 0 && !domClass.contains(node, "mandatory"))) {
 domClass.add(node, "has-success");
 domClass.remove(node, "has-error");
 } else {
 this._showErrorMessageDiv(error, node.children[0]);
 domClass.add(node, "has-error");
 if (iskeyPress && inputValue.length === 0 && !domClass.contains(node, "mandatory")) {
 // create a map based on the input web map id
 _createWebMap: function (itemInfo) {
 var mouseWheel; //To capture the mouse-wheel scroll event and then later deactivate it
 var popup = new Popup({
 highlight: false
 }, domConstruct.create("div"));
 domClass.add(popup.domNode, 'light');
 var mapDiv = dom.byId('mapDiv');
 // fullscreen button HTML
 if (this.config.enableBasemapToggle) {
 var fsHTML = '';
 fsHTML = '<div class="basemapToggle-button"><div class="basemapToggle-button" id="BasemapToggle"></div></div>';
 fsHTML += '</div>';
 mapDiv.innerHTML = fsHTML;
 arcgisUtils.createMap(itemInfo, mapDiv, {
 mapOptions: {
 infoWindow: popup
 // Optionally define additional map config here for example you can
 // turn the slider off, display info windows, disable wraparound 180, slider position and more.
 editable: true,
 usePopupManager: false,
 layerMixins: this.config.layerMixins || [],
 bingMapsKey: this.config.bingKey
 }).then(lang.hitch(this, function (response) {
 // Once the map is created we get access to the response which provides important info
 // such as the map, operational layers, popup info and more. This object will also contain
 // any custom options you defined for the template. In this example that is the 'theme' property.
 // Here' we'll use it to update the application to match the specified color theme.
 // console.log(this.config);
 this._createGeoformSections();
 this.map = response.map;
 // Disable scroll zoom handler
 var toggle = new basemapToggle({
 map: this.map,
 basemap: this.config.defaultBasemap,
 defaultBasemap: this.config.nextBasemap
 }, "BasemapToggle");
 toggle.startup();
var layers = this.map.getLayersVisibleAtScale(this.map.getScale());
 on.once(this.map, 'basemap-change', lang.hitch(this, function () {
 for (var i = 0; i < layers.length; i++) {
 if (layers[i]._basemapGalleryLayerType) {
 var layer = this.map.getLayer(layers[i].id);
 this.map.removeLayer(layer);
 this.map.disableScrollWheelZoom();
 this.defaultExtent = this.map.extent;
 // webmap defaults
 this._setWebmapDefaults();
 // default layer
 this._setLayerDefaults();
 // set configuration
 this._setAppConfigurations(this.config.details);
 domAttr.set(dom.byId('submitButton'), "innerHTML", this.config.submitButtonText ? this.config.submitButtonText : nls.user.submitButtonText);
 domAttr.set(dom.byId('viewSubmissionsButton'), "innerHTML", this.config.viewSubmissionsText ? this.config.viewSubmissionsText : nls.user.btnViewSubmissions);
 // window title
 if (this.config.details && this.config.details.Title) {
 window.document.title = this.config.details.Title;
 if (this.config.form_layer.id == "all") {
 var webmapLayers, deferredListArray = [];
 this.layerCollection = {};
 webmapLayers = domConstruct.create("select", {
 "class": "form-control selectDomain allLayerList"
 }, dom.byId("multipleLayers"));
 for (var key in this.config.fields) {
 if (this.config.fields.hasOwnProperty(key) && key !== "length") {
 deferredListArray.push(this._loadNewLayer(webmapLayers, key));
 //run this block after all the layers are loaded and are correspondingly pushed in the layer-select-box
 all(deferredListArray).then(lang.hitch(this, function () {
 //if at-least one editable point layer is found then create the form or else show error message
 if (webmapLayers.options[0]) {
 webmapLayers.options[0].selected = true;
 this._formLayer = this.layerCollection[webmapLayers.options[0].value];
 this._savedFields = this.config.fields[webmapLayers.options[0].value];
 on(webmapLayers, "change", lang.hitch(this, function (evt) {
 this._savedFields = this.config.fields[evt.currentTarget.value];
 this._formLayer = this.layerCollection[evt.currentTarget.value];
 this._resizeMap();
 } else {
 var error = new Error(nls.user.invalidLayerMessage);
 } else {
 this._savedFields = this.config.fields[this._formLayer.id];
 // create form fields
 // create locate button
 this._createLocateButton();
 // create geocoder button
 this._createGeocoderButton();
 // make graphics layer
 this._gl = new GraphicsLayer();
 this.map.addLayer(this._gl);
 // add border radius to map
 domClass.add(this.map.root, 'panel');
 // drag point edit toolbar
 this.editToolbar = new editToolbar(this.map);
 // start moving
 on(this.editToolbar, "graphic-move-start", lang.hitch(this, function () {
 this.map.infoWindow.hide();
 // stop moving
 on(this.editToolbar, "graphic-move-stop", lang.hitch(this, function (evt) {
 var locationCoords = this._calculateLatLong(evt.graphic.geometry);
 domAttr.set(dom.byId("coordinatesValue"), "innerHTML", locationCoords);
 this.addressGeometry = evt.graphic.geometry;
 this._setCoordInputs(evt.graphic.geometry);
 // show info window on graphic click
 on(this.editToolbar, "graphic-click", lang.hitch(this, function (evt) {
 var graphic = evt.graphic;
 if (graphic && this.map.infoWindow) {
 this.map.infoWindow.setFeatures([graphic]);
 // map click
 on(this.map, 'click', lang.hitch(this, function (evt) {
 //remove the location-error message as soon as the point on the map is selected.
 this._clearSubmissionGraphic();
 this.addressGeometry = evt.mapPoint;
 this._setSymbol(this.addressGeometry, true);
 // get coords string
 var coords = this._calculateLatLong(evt.mapPoint);
 domAttr.set(dom.byId("coordinatesValue"), "innerHTML", coords);
 this._setCoordInputs(evt.mapPoint);
 //on mouse move show lat lon
 on(this.map, 'mouse-move', lang.hitch(this, function (evt) {
 mouseWheel = on(this.map, 'mouse-wheel', lang.hitch(this, function () {
 //Enables scrollwheel zoom 3 seconds after a user hovers over the map
 setTimeout(lang.hitch(this, function () {
 this.map.enableScrollWheelZoom();
 }), 3000);
 mouseWheel.remove();
 // Add desirable touch behaviors here
 if (this.map.hasOwnProperty("isScrollWheelZoom")) {
 if (this.map.isScrollWheelZoom) {
 } else {
 } else {
 // Default
 // FeatureLayers
 // resize popup
 on(this.map.infoWindow, "selection-change, set-features, show", lang.hitch(this, function () {
 this._resizeInfoWin();
 // When window resizes
 on(window, 'resize', lang.hitch(this, function () {
 this._resizeMap(true);
 this._centerPopup();
 // Lat/Lng coordinate events
 var latNode = dom.byId('lat_coord');
 var lngNode = dom.byId('lng_coord');
 on(latNode, "keyup", lang.hitch(this, function () {
 this._validateLocationInputs('lat');
 on(latNode, "keypress", lang.hitch(this, function (evt) {
 this._findLocation(evt);
 on(lngNode, "keypress", lang.hitch(this, function (evt) {
 on(lngNode, "keyup", lang.hitch(this, function () {
 this._validateLocationInputs('lng');
 // lat/lng changed
 on(latNode, "change", lang.hitch(this, function () {
 on(lngNode, "change", lang.hitch(this, function () {
 on(dom.byId('cordsSubmit'), a11yclick, lang.hitch(this, function (evt) {
 this._evaluateCoordinates(evt);
 // USNG
 on(dom.byId('usng_submit'), a11yclick, lang.hitch(this, function () {
 this._convertUSNG();
 var usngInput = dom.byId('usng_coord');
 on(usngInput, "change", lang.hitch(this, function () {
 this._checkUSNG();
 on(usngInput, "keypress", lang.hitch(this, function (evt) {
 var keyCode = evt.charCode || evt.keyCode;
 if (keyCode === 13) {
 this._checkUSNG();
 // MGRS
 on(dom.byId('mgrs_submit'), a11yclick, lang.hitch(this, function () {
 this._convertMGRS();
 var mgrsInput = dom.byId('mgrs_coord');
 on(mgrsInput, "change", lang.hitch(this, function () {
 this._checkMGRS();
 on(mgrsInput, "keypress", lang.hitch(this, function (evt) {
 this._checkMGRS();
 // UTM
 var northNode = dom.byId('utm_northing');
 var eastNode = dom.byId('utm_easting');
 var zoneNode = dom.byId('utm_zone_number');
 on(dom.byId('utm_submit'), a11yclick, lang.hitch(this, function () {
 this._convertUTM();
 on(northNode, "keypress", lang.hitch(this, function (evt) {
 this._convertUTM();
 this._checkUTM();
 on(northNode, "change", lang.hitch(this, function () {
 this._checkUTM();
 on(eastNode, "keypress", lang.hitch(this, function (evt) {
 this._convertUTM();
 this._checkUTM();
 on(eastNode, "change", lang.hitch(this, function () {
 this._checkUTM();
 on(zoneNode, "keypress", lang.hitch(this, function (evt) {
 this._convertUTM();
 this._checkUTM();
 on(zoneNode, "change", lang.hitch(this, function () {
 this._checkUTM();
 // fullscreen
 var fsButton = domConstruct.create("div", {
 tabindex: "0",
 "class": "fullScreenButtonContainer"
 }, mapDiv);
 title: "Full Screen",
 "class": "glyphicon glyphicon-fullscreen fullScreenImage"
 }, fsButton);
 if (fsButton) {
 on(fsButton, a11yclick, lang.hitch(this, function () {
 this._toggleFullscreen();
 // fullscreen esc key
 on(document.body, 'keyup', lang.hitch(this, function (evt) {
 if (keyCode === 27) {
 this._toggleFullscreen(false);
 // finished button
 var submitButtonNode = dom.byId('submitButton');
 if (submitButtonNode) {
 on(submitButtonNode, a11yclick, lang.hitch(this, function () {
 this._submitForm();
 //disable viewSubmissionsButton
 if (this.config.disableViewer) {
 domClass.add(dom.byId("viewSubmissionsButton"), 'hidden');
 domAttr.set(dom.byId("viewSubmissionsButton"), "href", this._viewSubmissions());
 // set location options
 this._populateLocationsOptions();
 // resize map
 this._resizeMap();
 // load map
 if (this.map.loaded) {
 this._mapLoaded();
 } else {
 // map loaded
 on(this.map, 'load', lang.hitch(this, function () {
 this._mapLoaded();
 //Check location parameters in url
 if (this.config.locate) {
 this._setLocation("locate", this.config.locate);
 } else if (this.config.search) {
 this._setLocation("search", this.config.search);
 } else if (this.config.latlon) {
 this._setLocation("latlon", this.config.latlon);
 }), this.reportError);
//this function opens viewer page
 _viewSubmissions: function () {
 var urlString = "viewer.html";
 urlString += "?appid=" + this.config.appid;
 } else if (this.config.webmap) {
 urlString += "?webmap=" + this.config.webmap;
 return urlString;
//this function ensures that the layer is either loaded or throws an error in console naming the layer that did not load successfully
 _loadNewLayer: function (webmapLayers, key) {
 var layerLoadedEvent, errorLoadEvent, def, layer;
 //Fetch all the layers at once
 def = new Deferred();
 layer = this.map.getLayer(key);
 //this block will be called if the layer is already loaded
 if (layer && layer.url) {
 if (layer.loaded) {
 if (layer.isEditable() && layer.geometryType === 'esriGeometryPoint') {
 this._pushToLayerDrpDwn(webmapLayers, key, layer);
 def.resolve();
 } else {
 //this block will be called if there is some error in layer load
 if (layer.loadError) {
 console.log(nls.user.error + ": " + layer.name);
 def.resolve();
 //this block attaches 'load' and 'loadError' events respectively
 else {
 layerLoadedEvent = on.once(layer, "load", lang.hitch(this, function () {
 errorLoadEvent.remove();
 def.resolve();
 errorLoadEvent = on.once(layer, "error", lang.hitch(this, function () {
 layerLoadedEvent.remove();
 def.resolve();
 } else {
 //This error will be logged in case the layer is undefined
 //this will happen in case where the key from this.config.fields supplies a layer id not present in the map
 console.log(nls.user.invalidLayerMessage + ": " + key);
 def.resolve();
 return def.promise;
 //function to push the layer name to layer drop down
 _pushToLayerDrpDwn: function (webmapLayers, key, layer) {
 this.layerCollection[key] = layer;
 var option = domConstruct.create("option", {}, webmapLayers);
 option.text = this.layerCollection[key].name;
 option.value = key;
 _createGeoformSections: function () {
 array.forEach(query(".geoformSection"), lang.hitch(this, function (currentSection, index) {
 if (this.config.form_layer.id === "all") {
 currentSection.innerHTML = string.substitute(currentSection.innerHTML, {
 formSection: ++index + "."
 } else {
 if (index !== 0) {
 formSection: index + "."
 } else {
 domStyle.set(dom.byId("selectLayer"), "display", "none");
_mapLoaded: function () {
 // center coords
 var mapCenter = this.map.extent.getCenter();
 if (mapCenter) {
 this._setCoordInputs(mapCenter);
 var locationCoords = this._calculateLatLong(mapCenter);
 this._resizeMap();
 }), 500);
 // resize map
 this._resizeMap();
 }), 1000);
_setLocation: function (urlParameter, value) {
 switch (urlParameter) {
 case "locate":
 this.currentLocation.locate();
 break;
 case "search":
 this.geocodeAddress.set("value", value);
 this.geocodeAddress.search();
 break;
 case "latlon":
 var latlonValue = value.split(",");
 this._locatePointOnMap(latlonValue[0], latlonValue[1], 'latlon');
 domAttr.set(dom.byId('lat_coord'), "value", latlonValue[0]);
 domAttr.set(dom.byId('lng_coord'), "value", latlonValue[1]);
 break;
 default:
 //Code for default value
 break;
 _fullscreenState: function () {
 // get all nodes
 var mapNode, fsContainerNode, btnNode, mapContainerNode;
 mapNode = dom.byId('mapDiv');
 fsContainerNode = dom.byId('fullscreen_container');
 mapContainerNode = dom.byId('map_container');
 btnNode = dom.byId('fullscreen_icon');
 if (domClass.contains(document.body, 'fullscreen')) {
 domClass.remove(this.map.root, 'panel');
 domConstruct.place(mapNode, fsContainerNode);
 domClass.replace(btnNode, "glyphicon glyphicon-remove", "glyphicon glyphicon-fullscreen");
 // move map node and clear hash
 window.location.hash = "";
 btnNode.title = nls.user.mapRestore;
 } else {
 domConstruct.place(mapNode, mapContainerNode);
 domClass.replace(btnNode, "glyphicon glyphicon-fullscreen", "glyphicon glyphicon-remove");
 window.location.hash = "#mapDiv";
 btnNode.title = nls.user.mapFullScreen;
 this._resizeMap();
 // if current selected location
 this.map.centerAt(this.addressGeometry);
 }), 500);
 _toggleFullscreen: function (condition) {
 // swap classes
 domClass.toggle(document.body, 'fullscreen', condition);
 // update state
 this._fullscreenState();
 _validateLocationInputs: function (mode) {
 switch (mode) {
 case 'lat':
 var lat = lang.trim(dom.byId('lat_coord').value);
 if (lat === '') {
 domClass.remove(dom.byId('lat_coord').parentNode, 'has-error');
 domClass.remove(dom.byId('lat_coord').parentNode, 'has-success');
 return;
 if (lat >= -90 && lat <= 90) {
 domClass.replace(dom.byId('lat_coord').parentNode, 'has-success', 'has-error');
 } else {
 domClass.replace(dom.byId('lat_coord').parentNode, 'has-error', 'has-success');
 break;
 case 'lng':
 var lng = lang.trim(dom.byId('lng_coord').value);
 if (lng === '') {
 domClass.remove(dom.byId('lng_coord').parentNode, 'has-error');
 domClass.remove(dom.byId('lng_coord').parentNode, 'has-success');
 return;
 if (lng >= -180 && lng <= 180) {
 domClass.replace(dom.byId('lng_coord').parentNode, 'has-success', 'has-error');
 } else {
 domClass.replace(dom.byId('lng_coord').parentNode, 'has-error', 'has-success');
 break;
 // utm to lat lon
 _convertUTM: function () {
 var northing = parseFloat(dom.byId('utm_northing').value);
 var easting = parseFloat(dom.byId('utm_easting').value);
 var zoneString = zoneNode.value;
var zoneLastChar = zoneString.substr(zoneString.length-1);
var zone = parseInt(zoneString, 10);
if(isNaN(zoneLastChar)){
 if(zoneLastChar.toLowerCase() === "s"){
 northing = Math.abs(northing) - NORTHING_OFFSET;
 else{
 northing = Math.abs(northing);
var converted = {};
 try {
 usng.UTMtoLL(northing, easting, zone, converted);
 } catch (e) {
 this._coordinatesError('utm');
 if (converted) {
 this._locatePointOnMap(converted.lat, converted.lon, 'utm');
 // usng to lat lon
 _convertUSNG: function () {
 var value = dom.byId('usng_coord').value;
 var converted = [];
 try {
 usng.USNGtoLL(value, converted);
 } catch (e) {
 this._coordinatesError('usng');
 if (converted.length === 2) {
 this._locatePointOnMap(converted[0], converted[1], 'usng');
 // convert mgrs to lat lon
 _convertMGRS: function () {
 var value = dom.byId('mgrs_coord').value;
 var converted = [];
 try {
 } catch (e) {
 this._coordinatesError('mgrs');
 this._locatePointOnMap(converted[0], converted[1], 'mgrs');
 // make sure valid coordinates
 _evaluateCoordinates: function () {
 if (latNode.value === "") {
 this._showErrorMessageDiv(nls.user.emptylatitudeAlertMessage, dom.byId("select_location"));
 return;
 } else if (lngNode.value === "") {
 this._showErrorMessageDiv(nls.user.emptylongitudeAlertMessage, dom.byId("select_location"));
 return;
 // place on map
 this._locatePointOnMap(latNode.value, lngNode.value, 'latlon');
 _checkLatLng: function () {
 // make sure lat and lon are both filled out to show button
 var coord = dom.byId('cordsSubmit');
 if (lat && lng) {
 domAttr.remove(coord, 'disabled');
 } else {
 domAttr.set(coord, 'disabled', 'disabled');
 _checkUTM: function () {
 var e = dom.byId('utm_northing').value;
 var n = dom.byId('utm_easting').value;
 var z = dom.byId('utm_zone_number').value;
 var s = dom.byId('utm_submit');
 if (e && n && z) {
 domAttr.remove(s, 'disabled');
 } else {
 domAttr.set(s, 'disabled', 'disabled');
 _checkUSNG: function () {
 // make value(s) are set
 var inputVal = dom.byId('usng_coord').value;
 var btn = dom.byId('usng_submit');
 if (inputVal) {
 domAttr.remove(btn, 'disabled');
 } else {
 domAttr.set(btn, 'disabled', 'disabled');
 _checkMGRS: function () {
 var inputVal = dom.byId('mgrs_coord').value;
 var btn = dom.byId('mgrs_submit');
 if (inputVal) {
 } else {
 // find location for coordinates
 _findLocation: function (evt) {
 // check coordinates
 this._evaluateCoordinates();
 // my location button
 _createLocateButton: function () {
 // create widget
 this.currentLocation = new LocateButton({
 map: this.map,
 highlightLocation: false,
 theme: "btn btn-default"
 }, domConstruct.create('div'));
 this.currentLocation.startup();
 if(this.currentLocation.visible){
 // on current location submit
 on(this.currentLocation, "locate", lang.hitch(this, function (evt) {
 // remove error
 var errorMessageNode = dom.byId('errorMessageDiv');
 domConstruct.empty(errorMessageNode);
 // if error
 if (evt.error) {
 alert(nls.user.locationNotFound);
 } else {
 this._setSymbol(evt.graphic.geometry);
 this._resizeMap();
 //If the location is found we will remove the location-error message if it exists
 // reset button
 $('#geolocate_button').button('reset');
 // event for clicking node
 on(dom.byId('geolocate_button'), a11yclick, lang.hitch(this, function (evt) {
 // remove graphic
 // set loading button
 $('#geolocate_button').button('loading');
 // widget locate
 evt.stopPropagation();
 evt.preventDefault();
 else{
 $('#geolocate_button').addClass('hidden');
// geocoder with bootstrap
 _createGeocoderButton: function () {
 var searchOptions = {
 map: this.map,
 geocoders: this.config.helperServices.geocode || [],
 itemData: this.config.itemInfo.itemData
 if (this.config.searchConfig) {
 searchOptions.enableSearchingAll = this.config.searchConfig.enableSearchingAll;
 searchOptions.activeSourceIndex = this.config.searchConfig.activeSourceIndex;
 searchOptions.applicationConfiguredSources = this.config.searchConfig.sources || [];
 } else {
 var configuredSearchLayers = (this.config.searchLayers instanceof Array) ? this.config.searchLayers : JSON.parse(this.config.searchLayers);
 searchOptions.configuredSearchLayers = configuredSearchLayers;
 searchOptions.geocoders = this.config.locationSearch ? this.config.helperServices.geocode : [];
 var searchSources = new SearchSources(searchOptions);
 // get options
 var createdOptions = searchSources.createOptions();
 createdOptions.enableHighlight = false;
 createdOptions.enableInfoWindow = false;
 // create geocoder
 this.geocodeAddress = new Search(createdOptions, "search-widget");
 this.geocodeAddress.startup();
 // on find
 on(this.geocodeAddress, "select-result", lang.hitch(this, function (evt) {
 var coords = this._calculateLatLong(evt.result.feature.geometry);
 //this will remove the error message if it exists
 this.addressGeometry = evt.result.feature.geometry;
 this._setSymbol(evt.result.feature.geometry);
 this.map.centerAt(evt.result.feature.geometry).then(lang.hitch(this, function () {
 this._resizeMap();
// submit form with applyedits
 _addFeatureToLayer: function () {
 var userFormNode, featureData, key, value, defaultValue;
 //To populate data for apply edits
 featureData = new Graphic();
 featureData.attributes = {};
 // start with layer defaults
 if (this._formLayer.templates[0] && this._formLayer.templates[0].prototype.attributes) {
 featureData.attributes = lang.clone(this._formLayer.templates[0].prototype.attributes);
 //condition to filter out radio inputs
 array.forEach(query(".geoFormQuestionare .form-control"), function (currentField) {
 key = domAttr.get(currentField, "id");
 if (currentField.value !== "") {
 if (domClass.contains(currentField, "hasDatetimepicker")) {
 var picker = $(currentField.parentNode).data('DateTimePicker');
 var d = picker.date();
 // need to get time of date in ms for service
 value = d.valueOf();
 } else {
 value = lang.trim(currentField.value);
 featureData.attributes[key] = value;
 else if(domAttr.has(currentField, "data-default-value")){
 defaultValue = domAttr.get(currentField, "data-default-value");
 value = defaultValue;
 array.forEach(query(".filterSelect"), function (currentField) {
 if (currentField.value) {
 // each radio button
 array.forEach(query(".geoFormQuestionare .radioContainer"), function (currentField) {
 var radioFields = query(".radioInput:checked", currentField);
 if (radioFields.length) {
 var selectedField = radioFields[0];
 key = selectedField.name;
 value = lang.trim(selectedField.value);
 // each checkbox
 array.forEach(query(".geoFormQuestionare .checkboxContainer"), function (currentField) {
 key = query(".checkboxInput", currentField)[0].id;
 value = query(".checkboxInput:checked", currentField).length;
 featureData.geometry = {};
 featureData.geometry = new Point(Number(this.addressGeometry.x), Number(this.addressGeometry.y), this.map.spatialReference);
 //code for apply-edits
 this._formLayer.applyEdits([featureData], null, null, lang.hitch(this, function (addResults) {
 // Add attachment on success
 if (addResults[0].success && this.isHumanEntry) {
 if (query(".fileToSubmit", userFormNode).length === 0) {
 this._resetAndShare();
 } else {
 this._openFileUploadStatusModal(query(".fileToSubmit", userFormNode));
 var fileObjArray = [];
 for (var i = 0; i < query(".formToSubmit", userFormNode).length; i++) {
 fileObjArray.push(query(".formToSubmit", userFormNode)[i].id);
 this.arrPendingAttachments = fileObjArray.reverse();
 this._addAttachment(addResults[0].objectId, dom.byId(this.arrPendingAttachments.pop()));
 return true;
 domConstruct.destroy(query(".errorMessage")[0]);
 // open error modal if unsuccessful
 if (!addResults[0].success || (!this.isHumanEntry && addResults[0].success)) {
 var error;
 if(!addResults[0].success){
 error = addResults[0].error || new Error("");
 else {
 error = new Error(nls.user.applyEditsFailedRobot);
 this._openErrorModal(error);
 return;
 }), lang.hitch(this, function (error) {
 // no longer editable
 this._formLayer.setEditable(false);
 // remove error
 // open error
 // log for development
 console.log(nls.user.addFeatureFailedMessage);
 _resetAndShare: function () {
 // remove graphic
 // reset form
 this._clearFormFields();
 // reset to default extent
 if (this.config.defaultMapExtent) {
 this.map.setExtent(this.defaultExtent);
 this._openShareModal();
// reset submit button
 this._resetButton();
 window.location.href = '#top';
 // After moving geoform to top, map was not getting resized properly.
 // And pushpin was not getting placed correctly.
 this._resizeMap();
 _addAttachment: function (recordId, currentElement) {
 var currentBadge;
 this.flagAttachingPrevFile = true;
 currentBadge = query(".file-upload-status-badge[data-badge=" + currentElement[0].id + "]")[0];
 //re-enabling the file i/p field before sending to attach
 domAttr.set(currentElement[0], "disabled", false);
 this._formLayer.addAttachment(recordId, currentElement, lang.hitch(this, function () {
 if (dom.byId("fileUploadStatusMsgContainer")) {
 this.flagAttachingPrevFile = false;
 //adding/removing attributes to keep the user updated on current state of file attachment
 domClass.replace(currentBadge.parentNode, "alert-success", "alert-info");
 domClass.replace(currentBadge, "glyphicon-ok", "glyphicon-upload");
 domStyle.set(currentBadge, "cursor", "auto");
 currentBadge.innerHTML = nls.user.successBadge;
 if (this.arrRetryAttachments.length !== 0) {
 this._addAttachment(recordId, dom.byId(this.arrRetryAttachments.pop()));
 return true;
 if (this.arrPendingAttachments.length !== 0) {
 this._addAttachment(recordId, dom.byId(this.arrPendingAttachments.pop()));
 return true;
 }), lang.hitch(this, function () {
 //condition to check whether file upload status modal is open or not
 //Keep a copy of ids that failed to upload to pick them back while retrying to upload the failed file
 this.objFailedAttachments[currentElement[0].id] = currentElement.id;
 domClass.replace(currentBadge.parentNode, "alert-warning", "alert-info");
 domClass.remove(query(".attachment-error-message", currentBadge.parentNode)[0], "hide");
 domClass.replace(currentBadge, "btn btn-danger btn-xs", "glyphicon-upload");
 currentBadge.innerHTML = nls.user.retryBadge;
 domStyle.set(currentBadge, "cursor", "pointer");
 //This click event will work on retry button in case of failure in attachment
 //and process to re-upload the file will start
 on.once(currentBadge, a11yclick, lang.hitch(this, function (evt) {
 domClass.replace(currentBadge.parentNode, "alert-info", "alert-warning");
 domClass.add(query(".attachment-error-message", currentBadge.parentNode)[0], "hide");
 domClass.replace(currentBadge, "glyphicon-upload", "btn btn-danger btn-xs glyphicon-repeat");
 evt.currentTarget.innerHTML = nls.user.uploadingBadge;
 domStyle.set(evt.currentTarget, "cursor", "auto");
 this.arrRetryAttachments.push(this.objFailedAttachments[domAttr.get(evt.currentTarget, "data-badge")]);
 delete this.objFailedAttachments[domAttr.get(evt.currentTarget, "data-badge")];
 if (this.flagAttachingPrevFile === false) {
 return true;
 console.log(nls.user.addAttachmentFailedMessage);
 return true;
 return true;
 // remove point graphic
 _clearSubmissionGraphic: function () {
 this.addressGeometry = null;
 this._gl.clear();
 if (this.map.infoWindow && this.map.infoWindow.isShowing) {
 // display coordinates error
 _coordinatesError: function (type) {
 switch (type) {
 case "utm":
 this._showErrorMessageDiv(nls.user.invalidUTM, dom.byId("select_location"));
 break;
 case "usng":
 this._showErrorMessageDiv(nls.user.invalidUSNG, dom.byId("select_location"));
 break;
 case "mgrs":
 this._showErrorMessageDiv(nls.user.invalidMGRS, dom.byId("select_location"));
 break;
 default:
 this._showErrorMessageDiv(nls.user.invalidLatLong, dom.byId("select_location"));
 _projectPoint: function (geometry) {
 // this function takes a lat/lon (4326) point and converts it to map's spatial reference.
 var def = new Deferred();
 // maps spatial ref
 var sr = this.map.spatialReference;
 // map and point are both lat/lon
 if (sr.wkid === 4326) {
 def.resolve(geometry);
 // map is mercator
 else if (sr.isWebMercator()) {
 // convert lat lon to mercator. No network request.
 var pt = webMercatorUtils.geographicToWebMercator(geometry);
 def.resolve(pt);
 // map is something else & has geometry service
 else if (esriConfig.defaults.geometryService) {
 // project params
 var params = new ProjectParameters();
 params.geometries = [geometry];
 params.outSR = this.map.spatialReference;
 // use geometry service to convert lat lon to map format (network request)
 esriConfig.defaults.geometryService.project(params).then(function (projectedPoints) {
 if (projectedPoints && projectedPoints.length) {
 def.resolve(projectedPoints[0]);
 } else {
 def.reject(new Error("GeoForm::Point was not projected."));
 }, function (error) {
 def.reject(error);
 // cant do anything, leave lat/lon
 else {
 return def;
 // put x,y point on map in mercator
 _locatePointOnMap: function (x, y, type) {
 if (x >= -90 && x <= 90 && y >= -180 && y <= 180) {
 var mapLocation = new Point(y, x);
 // convert point
 this._projectPoint(mapLocation).then(lang.hitch(this, function (pt) {
 if (pt) {
 this._removeErrorNode(dom.byId("select_location").nextSibling);
 this.addressGeometry = pt;
 // set point symbol
 this._setSymbol(pt);
 // center map at point and resize
 this.map.centerAt(pt).then(lang.hitch(this, function () {
 this._resizeMap();
 console.log(error);
 this._coordinatesError(type);
 } else {
 // open modal
 _openShareModal: function () {
 // destroy modal if it exists
 if (this._ShareModal) {
 this._ShareModal.destroy();
 // create modal content
 this._createShareDlgContent();
 // create modal
 this._ShareModal = new ShareModal({
 image: this.config.sharinghost + '/sharing/rest/content/items/' + this.config.itemInfo.item.id + '/info/' + this.config.itemInfo.item.thumbnail,
 title: this.config.details.Title || nls.user.geoformTitleText || '',
 summary: this.config.itemInfo.item.snippet || '',
 hashtags: 'esriGeoForm',
 shareOption: this.config.enableSharing
 this._ShareModal.startup();
 // show modal
 $("#myModal").modal('show');
 domAttr.set(dom.byId("viewSubmissionsOption"), "href", this._viewSubmissions());
 // error modal content
 _openErrorModal: function (error) {
 var errorMsgContainer;
 domConstruct.empty(query(".modal-body")[0]);
 domAttr.set(dom.byId('myModalLabel'), "innerHTML", nls.user.error);
 errorMsgContainer = domConstruct.create("div", {}, query(".modal-body")[0]);
 var errorMessage = (error && error.message) || nls.user.applyEditsFailedMessage;
if(error && error.code === "IdentityManagerBase.1"){
 errorMessage = nls.user.applyEditsAuthError;
 className: "alert alert-danger errorMessage",
 innerHTML: errorMessage
 }, errorMsgContainer);
 _openFileUploadStatusModal: function (fileList) {
 var fileUploadStatusMsgContainer, fileUploadStatusMsgUl, fileUploadStatusMsgLi, fileUploadStatusMsgBadge;
 if (dom.byId("viewSubmissionsOption")) {
 domConstruct.destroy(query(".modal-footer")[0].children[1]);
 domAttr.set(dom.byId('myModalLabel'), "innerHTML", nls.user.fileUploadStatus);
 fileUploadStatusMsgContainer = domConstruct.create("div", {
 "id": "fileUploadStatusMsgContainer"
 fileUploadStatusMsgUl = domConstruct.create("ul", {
 "class": "list-group"
 }, fileUploadStatusMsgContainer);
for (var i = 0; i < fileList.length; i++) {
 fileUploadStatusMsgLi = domConstruct.create("li", {
 "class": "message alert alert-info fileInputUI"
 }, fileUploadStatusMsgUl);
 fileUploadStatusMsgBadge = domConstruct.create("span", {
 "class": "pull-right file-upload-status-badge glyphicon glyphicon-upload",
 "innerHTML": nls.user.uploadingBadge,
 "id": "badge" + i
 }, fileUploadStatusMsgLi);
 "class": "pull-right hide attachment-error-message",
 "innerHTML": nls.user.errorBadge
 fileUploadStatusMsgLi.innerHTML += fileList[i].value.split('\\').pop();
 domAttr.set(dom.byId("badge" + i), "data-badge", fileList[i].id);
 $('#myModal').on('hidden.bs.modal', lang.hitch(this, function () {
 // share modal content
 _createShareDlgContent: function () {
 var iconContainer, group;
 // empty modal node
 // set modal title
 domAttr.set(dom.byId('myModalLabel'), "innerHTML", nls.user.shareUserTitleMessage);
 // create nodes for modal
 iconContainer = domConstruct.create("div", {
 className: "iconContainer"
 className: "alert alert-success",
 role: "alert",
 innerHTML: nls.user.entrySubmitted
 }, iconContainer);
 if (this.config.enableSharing) {
 domConstruct.create("h3", {
 innerHTML: nls.user.shareThisForm
 }, iconContainer);
 innerHTML: nls.user.shareUserTextMessage
 }, iconContainer);
 domConstruct.create("a", {
 "tabindex": "0",
 className: "fa fa-facebook-square iconClass text-primary",
 }, iconContainer);
 "tabindex": "0",
 className: "fa fa-twitter-square iconClass text-primary",
 }, iconContainer);
 "tabindex": "0",
 className: "fa fa-google-plus-square iconClass text-primary",
 }, iconContainer);
 "tabindex": "0",
 className: "fa fa-envelope iconClass text-primary",
 }, iconContainer);
 className: "clearfix"
 }, iconContainer);
 innerHTML: nls.user.shareModalFormText
 }, iconContainer);
 group = domConstruct.create("div", {
 className: "input-group"
 }, iconContainer);
 className: "input-group-addon",
 innerHTML: "<span class=\"glyphicon glyphicon-link\"></span>"
 }, group);
 type: "text",
 }, group);
 className: "btn btn-default pull-left",
 href: "#",
 innerHTML: this.config.viewSubmissionsText ? this.config.viewSubmissionsText : nls.user.btnViewSubmissions
 }, query(".modal-footer")[0]);
 domClass.add(dom.byId("viewSubmissionsOption"), "hidden");
 // display error message
 _showErrorMessageDiv: function (errorMessage, errorMessageNode) {
 // clear node
 var errorNode, place = "after";
 if (errorMessageNode.id === "errorMessageDiv") {
 place = "only";
 if (errorMessageNode) {
 this._removeErrorNode(errorMessageNode.nextSibling);
 // create node
 errorNode = domConstruct.create("div", {
 id: "errorMessage" + errorMessageNode.id,
 }, null);
 domConstruct.place(errorNode, errorMessageNode, place);
 // resize map
 this._resizeMap();
 _resetButton: function () {
 var btn = $(dom.byId('submitButton'));
 btn.button('reset');
 // set defaults for layer
 _setLayerDefaults: function () {
 var error, flagPointFeatureLayer;
 // if no layer id is set, try to use first feature layer
 if (!this.config.form_layer || !this.config.form_layer.id) {
 flagPointFeatureLayer = false;
 array.some(this.config.itemInfo.itemData.operationalLayers, lang.hitch(this, function (currentLayer) {
 if (currentLayer.layerType && currentLayer.layerType === "ArcGISFeatureLayer") {
 if (currentLayer.resourceInfo.geometryType === 'esriGeometryPoint') {
 flagPointFeatureLayer = true;
 // if no object present
 if (!this.config.form_layer) {
 this.config.form_layer = {};
 // set id
 this.config.form_layer.id = currentLayer.id;
 //Add the default fields in the fields object
 //This case will work when application is running without app id
 if(!this.config.fields.hasOwnProperty(this.config.form_layer.id)){
 this.config.fields[this.config.form_layer.id] = this.map.getLayer(this.config.form_layer.id).fields;
 return true;
 } else {
 if (!flagPointFeatureLayer) {
 this.reportError(error);
 // get editable layer
 this._formLayer = this.map.getLayer(this.config.form_layer.id);
 // if we have a layer
 if (this._formLayer) {
 // if fields not set or empty
 var isFieldsEmpty = this._isFieldsEmpty(this.config.fields);
 if (!this.config.fields || (this.config.fields && isFieldsEmpty)) {
 array.some(this.config.itemInfo.itemData.operationalLayers, lang.hitch(this, function (operationalLayer, index) {
 //condition to catch the right layer from webmap
 if (operationalLayer.id === this._formLayer.id) {
 //This loop runs through all the fields configured in the popup
 array.forEach(this.config.itemInfo.itemData.operationalLayers[index].popupInfo.fieldInfos, lang.hitch(this, function (popupField) {
 //This loop will run through all the fields in the formLayer and will break when the field matches with currently selected field of pop
 array.some(this._formLayer.fields, lang.hitch(this, function (formLayerField) {
 //condition to match the popup field with the formLayer field to mixin the properties of object.
 if (formLayerField.name === popupField.fieldName) {
 //condition to show a type field irrespective of it's configured edit property.
 if (formLayerField.name === this._formLayer.typeIdField) {
 popupField.isEditable = true;
 formLayerField.alias = popupField.label;
 formLayerField.editable = popupField.isEditable;
 formLayerField.visible = popupField.isEditable;
 formLayerField.tooltip = popupField.tooltip;
 formLayerField.locked = popupField.locked;
 this.config.fields[this._formLayer.id].push(formLayerField);
 return true;
 return true;
 if (this.config.showLayer) {
 this._formLayer.setVisibility(true);
 } else {
 this._formLayer.setVisibility(false);
 //This logic will convert the old array structure to equivalent object
 if (this.config.fields.length) {
 var fieldsArray = lang.clone(this.config.fields);
 this.config.fields = {};
 this.config.fields[this._formLayer.id] = fieldsArray;
 } else {
 if (this.config.form_layer.id !== "all") {
 return;
 _isFieldsEmpty: function (object) {
 for (var key in object) {
 if (object[key]) {
 return false;
 return true;
 // set defaults for app settings
 _setWebmapDefaults: function () {
 // if details not defined
 if (!this.config.details) {
 this.config.details = {};
 // if no app title
 if (!this.config.details.Title) {
 if (this._appResponse && this._appResponse.item) {
 // use app title
 this.config.details.Title = this._appResponse.item.title;
 // if item
 if (this.config.itemInfo && this.config.itemInfo.item) {
 // use webmap title
 this.config.details.Title = this.config.itemInfo.item.title;
 // if no app description
 if (!this.config.details.Description) {
 // if item
 // use webmap snippet
 this.config.details.Description = this.config.itemInfo.item.snippet;
 // if no app logo
 if (!this.config.details.Logo) {
 // if item and thumb
 if (this.config.itemInfo && this.config.itemInfo.item && this.config.itemInfo.item.thumbnail) {
 // use webmap logo
 this.config.details.Logo = this.config.sharinghost + "/sharing/rest/content/items/" + this.config.webmap + '/info/' + this.config.itemInfo.item.thumbnail;
 // resize map
 _resizeMap: function (force) {
 if (this.map) {
 this.map.reposition();
 this.map.resize(force);
 // set visible location options
 _populateLocationsOptions: function () {
 var count = 0,
 total = 0,
 locationTabs, tabContents;
 locationTabs = query("#location_pills li");
 tabContents = query("#location_tabs .tab-pane");
 if (!this.config.locationSearchOptions) {
 this.config.locationSearchOptions = {
 "enableMyLocation": true,
 "enableSearch": true,
 "enableLatLng": true,
 "enableUSNG": false,
 "enableMGRS": false,
 "enableUTM": false
 for (var key in this.config.locationSearchOptions) {
 if (this.config.locationSearchOptions.hasOwnProperty(key) && key !== "enableMyLocation") {
 for(var i = 0; i < locationTabs.length; i++){
 var tab = locationTabs[i];
 var tabId = domAttr.get(tab, "data-tab-id");
 if(tabId === key){
 domStyle.set(tab, 'display', this.config.locationSearchOptions[key] ? "block" : "none");
 on(tab, a11yclick, lang.hitch(this, this._resizeMap));
 total++;
 if (!this.config.locationSearchOptions.enableMyLocation) {
 domStyle.set(dom.byId("geolocate_button"), 'display', 'none');
 if (!this.config.locationSearchOptions.enableSearch) {
 domStyle.set(dom.byId("search-widget"), 'display', 'none');
 //add 'active' class to first tab and its content
 array.some(locationTabs, lang.hitch(this, function (tab, idx) {
 if (domStyle.get(tab, 'display') == 'block') {
 domClass.add(tab, 'active');
 domClass.add(tabContents[idx], 'active');
 return true;
 if (total > 1) {
 dom.byId("locationOptionDescriptor").innerHTML = nls.user.locationDescriptionForMoreThanOneOption;
 } else {
 // hide tab nav if zero or one tabs
 var node = dom.byId('location_nav');
 if (node) {
 domStyle.set(node, 'display', 'none');
 var panelNode = dom.byId('location_panel');
 if (panelNode) {
 domClass.remove(panelNode, 'panel panel-default');
 var panelBodyNode = dom.byId('location_panel_body');
 if (panelBodyNode) {
 domClass.remove(panelBodyNode, 'panel-body');
 if (total === 1) {
 dom.byId("locationOptionDescriptor").innerHTML = nls.user.locationDescriptionForOneOption;
 } else {
 dom.byId("locationOptionDescriptor").innerHTML = nls.user.locationDescriptionForNoOption;
 // resize map
 this._resizeMap();
 _addNotationIcon: function (formContent, imageIconClass) {
 var inputIconGroupContainer, inputIconGroupAddOn;
 inputIconGroupContainer = domConstruct.create("div", {
 }, formContent);
 inputIconGroupAddOn = domConstruct.create("span", {
 }, inputIconGroupContainer);
 className: "glyphicon " + imageIconClass
 }, inputIconGroupAddOn);
 return inputIconGroupContainer;
 _getFormElement: function (currentDom) {
 var formElement = currentDom;
 while (!domClass.contains(formElement, "geoFormQuestionare")) {
 formElement = formElement.parentNode;
 return formElement;
 _createDateField: function (parentNode, isRangeField, fieldname, currentField, defaultValue) {
 domClass.add(parentNode, "date");
 var minDate, maxDate, defaultDate;
 if (currentField && currentField.preventPast) {
 minDate = new Date();
 if (currentField && currentField.preventFuture) {
 maxDate = new Date();
 if (currentField && currentField.setCurrentDate) {
 defaultDate = new Date();
 else if (defaultValue) {
 defaultDate = moment(defaultValue).format(this.dateFormat);
 var dateInputField = domConstruct.create("input", {
 type: "text",
 value: "",
 className: "form-control hasDatetimepicker",
 "data-input-type": "Date",
 "id": fieldname
 }, parentNode);
 on(dateInputField, "focus", function (e) {
 $(this.parentElement).data("DateTimePicker").show(e);
 on(dateInputField, "blur", function () {
 $(this.parentElement).data("DateTimePicker").hide();
 var dpOptions = {
 useStrict: false,
 locale: kernel.locale,
 minDate: minDate,
 maxDate: maxDate,
 format: this.dateFormat,
 defaultDate: defaultDate,
 useCurrent: true
 if (kernel.locale === "en" || kernel.locale === "en-us") {
 dpOptions.extraFormats = ["M/D/YYYY", "M-D-YYYY", "M.D.YYYY", "M D YYYY"];
 if (isRangeField && currentField.domain.minValue !== currentField.domain.maxValue && currentField.domain.minValue > -2147483648 && currentField.domain.maxValue > -2147483648) {
 dpOptions.minDate = moment(currentField.domain.minValue);
 dpOptions.maxDate = moment(currentField.domain.maxValue);
 $(parentNode).datetimepicker(dpOptions).on('dp.show', function (evt) {
 var picker = $(this).data('DateTimePicker');
 var selectedDate = picker.date();
 if (selectedDate === null) {
 query("input", this)[0].value = "";
 domClass.remove(query(evt.target).parents(".geoFormQuestionare")[0], "has-error");
 domClass.add(query(evt.target).parents(".geoFormQuestionare")[0], "has-success");
 if (query("input", this)[0].value === "") {
 domClass.remove(query(evt.target).parents(".geoFormQuestionare")[0], "has-success");
 }).on('dp.error', function (evt) {
 evt.target.value = '';
 domClass.add(query(evt.target).parents(".geoFormQuestionare")[0], "has-error");
 $(this).data("DateTimePicker").hide();
 }).on("dp.hide", function (evt) {
 }).on('dp.change', function (evt) {
 return dateInputField;
 _verifyHumanEntry: function () {
 this.isHumanEntry = false;
 this.isHumanEntry = true;
 }), 2000);
 //This function will remove the error message div.
 _removeErrorNode: function (node) {
 if (domClass.contains(node, "errorMessage")) {
 domConstruct.destroy(node);
});And again... any questions? Just let me know.
I customized the MAIN.JS and DEFAULT.JS files to allow for concatenated fields. I think I am going to try to use this experience to start work on an ATTRIBUTE ASSISTANT widget. We shall see...
Hello Brian,
Is this to store address into attribute from search location map? Please kindly confirm. Thank you for your assistance.
Alex
