Custom Logo in Header of MapTour
770
03-03-2014 08:09 AM
EldredAllen
In the Application Settings of my MapTour in AGOL under the Heading tab there is the option to add a custom logo, all you're supposed to do is provide the image URL under the specified size, but no matter what I do I cannot get the custom logo to appear.
I have an image stored on Flickr as a thumbnail, 116 x 50 pixels, and I copy the link to the image (not just the Flickr page) and put that in the URL section to customize the logo but alas it does nothing.
I cannot find an answer to this problem.  I have read another thread saying you cannot remove an ESRI logo but in AGOL it gives the option to do this so shouldn't it work?
Any one else experience this?
EldredAllen
I was able to add my logo to the Header of the MapTour by uploading my JPEG to AGOL into My Content and then sharing it publicly.  Once I did that I could copy the URL from AGOL and use it in the MapTour to set my Custom Logo in the Application Settings.
JonMontgomery
[RIGHT][/RIGHT]I've been able to change logos in my storymaps with no problem.  What kind of an image file is the logo you are trying to use? Also, have you tried using a smaller sized image?
Might also want to try posting in the story maps section of the forum to see if anyone there has any insight as well.
http://forums.arcgis.com/forums/264-Story-Maps
Best
EldredAllen
Thanks for the response Jon.  My image is quite a bit smaller than the requirement and it is a JPEG, I'll try the Storymap forum as you suggested as well.
EldredAllen
