custom attribute display using YEAR as part of URL
1108
01-04-2022 08:30 AM
by Anonymous User
Not applicable
I have a web app we've been using for years now and every year we have to go in to the URL properties of the custom attribute display and change the URL of a link to reflect the new year.
Ideally we can use the current year but I have no idea how to incorporate that as any code I try to put in the LINK properties shows up as text in the URL rather than returning the year.
Is there a way to access the current year in the URL field of a link in a custom attribute display?
In the URL below I hacked and tried adding javascript like Date.getFullYear() but it adds that to the URL string rather than running code to return current year.
Help is greatly appreciated.
jcarlson
Try creating a custom popup expression:
Year(Now())
And then piping that expression into your popup.
- Josh Carlson
Kendall County GIS
by Anonymous User
Not applicable
Where do I create the custom popup expression?
jcarlson
Click "Add" under "Attribute Expressions" on the "configure popup" panel.
- Josh Carlson
Kendall County GIS
by Anonymous User
Not applicable
Thanks. This app is currently on a server with an older version of portal and unfortunately the popup dialog doesn't show attribute expressions. That would be the way to do it though. Thank you!
