Create feature with Symbology graduated
3697
11-19-2015 01:44 PM
JosephJose
I have a point feature symbolized with graduated colors.
I have exposed it as a feature service in AGOL. Used the same in online version of WebApp Builder. I tried creating a new feature and when the Edit widget opens, I don't get the option to select the feature I want to create. (Check attached)
With features not symbolized with graduated colors, I have the option to create features.
Is there a way I can overcome this?
KyleBalke__GISP
Are you features symbolized with graduated colors in your ArcGIS Online web map?
Manage feature templates—ArcGIS Online Help | ArcGIS
JosephJose
Yes they are
KyleBalke__GISP
A screen shot of the layers in the web map you are using would be helpful.
JosephJose
Included screenshot
I can also give you the link which is personal. So feel free to play around
http://services3.arcgis.com/hfaVNNd4cu20LP0v/arcgis/rest/services/LabCollector/FeatureServer/0
JosephJose
I assume the current AGOL doesn't support features that are Symbology graduated.
I had to remove the symbology to enable editing
