'Counts & Amounts (size)' Style option in New Map Viewer - missing classify # of Natural Breaks like Classic Map Viewer
254
02-27-2025 12:10 PM
TraceyFinnegan-Wiese
Hello! Trying to transition from the Classic Map Viewer to the new Map viewer and am running into some functionality differences/missing features and hoping somebody can steer me in the correct direction.
In the old Classic Map Viewer if I wanted to classify data by a count field where the larger the circle (or symbol) on the map, the greater the data value. In Classic Map Viewer I would select the 'Counts & Amounts (size)' style and then have the option to Classify Data using 'Natural Breaks' with x classes (based on the number of classes, in my case usually 5 to 7). When I use this same style in the new map viewer and try to find this option of classifying data with natural breaks, I am unable to find it therefore cannot specify the number of breaks or classes that I want. Additionally, in the Classic Map Viewer I could click on each individual class (e.g. symbol/circle) and change the data label (say from 1-1 to 1, or 1-2 to 2) AND change the color. I don't see this option in the new map viewer to change the color or legend label of each count class. Is this possible in the new map viewer and if so, how do I do it. Thanks!
RussRoberts
Esri Notable Contributor
Hey Tracey,
In Map Viewer you can use classify under the Counts & Amounts (size) style.  Its located between the Size range slider and Transparency by attribute sections of the panel. From there you can set the number of classes, labels for the set classes and pick/configure your symbols for the classes. LMK if you have any further questions or if you want me to check out your map.
Thank you sooo much! I clearly missed that option when scrolling through the options. This clears up my questions - very much appreciate the efficient and accurate response!
LaurenReilly
Hi, I am having a similar issue, although my map viewer does not show the "classify data" option. Perhaps because I have my symbology set to Unique symbols (types) AND counts and amounts (size) ?
