Coordinate Systems of Hosted Feature Layers
3226
06-27-2023 11:13 AM
SLouq
by MVP Alum
I have a HFL which I created to work with a GNSS receiver and has a spatial reference in NAD 1983 2011 to match the coordinate system of the base station we use. That feature class works fine when collecting points with the GNSS receiver. Since then I have found other ways to use the GNSS receiver to collect Utility points for gas valves and water valves. So I created a new HFL based off my existing HFL using the Export Data and Publish tools in ArcGIS Online. When I did this, I noticed the Spatial Reference of the new HFL has changed from NAD 1983 2011 to WGS 1984 Web Mercator (auxiliary sphere) which is fine but now the points on my map are hidden and I can't see them. I know they are there bc the attributes are there in my attribute table and when I select one, it is selected in the map.
Why is this? And How can I fix it?
ChristopherCounsell
MVP Frequent Contributor
Uploading layers directly to ArcGIS Online will publish them as Web Mercator.
Publishing layers from ArcGIS Pro will use the map spatial reference. Typically this will be the first layer you add to the map - meaning it'll be the NAD 1983 2011.
It's likely that you had a projection issue resulting from publishing your data directly to ArcGIS Online via the web interface.
If you need to maintain a coordinate system or specific transformations, publish using ArcGIS Pro.
TonyContreras_Frisco_TX
Esri Documentation states that the features published to AGO use Web Mercator for the coordinate system. , What was the method you used to upload/publish the original HFL? Was it through the AGO website, or ArcGIS Pro connected to AGO? Whatever it was, I recommend using the same method. If you are exporting from AGO first, check the output CS and if it is Web Mercator, reproject it before attempting to upload/publish it.
SLouq
by MVP Alum
Thanks for the reply.
I got it to work for now at least. I had to open the working HFL in ArcGIS Pro. Export it to a feature class using NAD 1983 2011 as the coordinate system, then I shared that feature class with our ArcGIS Online account as a web layer. Don't know why but all the features copied and are visible now in that HFL
ChristopherCounsell
