Coordinate labels in Pro break in online web map
310
10-28-2025 11:05 AM
ThomasGoodridge
I'm working with the traverse editor in acrpro to check for closures. When I share it online the Direction field changes from dms, breaking the labels. Is there a way I could reverse this? The labels were made automatically by arcpro using this expression:
// Change the settings portion to configure direction format, color, rounding and abbreviations
// This is an Arcade expression
// SETTINGS
var QuadrantBearingFormat = true; //set 'true' for quadrant bearing, 'false' for north azimuth
var ShowDistance = true; //set as 'true' to show distance
var ShowDirection = true; //set as 'true' to show direction
var DirectionType = 1; // 1 = Quadrant Bearing; 2 = North Azimuth; 3 = South Azimuth
var ShowRadius = true; //set as 'true' to show radius
var ShowCurveParameter = true; //set as 'true' to show a curve parameter
var CurveParameter = "ArcLength"; //set as 'ArcLength' or 'Chord' or 'Angle' for central angle. Case sensitive!
var ErrorString = "COGO ERROR"; //set to display invalid COGO combinations
var RadiusAbbr = 'R='; //radius abbreviation
var Radius2Abbr = 'R2='; //radius2 abbreviation for spiral curves
var ArclengthAbrr = 'L='; //arclength abbreviation
var ChordAbbr = 'C='; //chord abbreviation
var AngleAbbr = 'A='; //central Angle abbreviation
var DistUnitRounding = 2; //number of decimal places for distance units: distance, radius, arclength & chord
var NumberFormat = "#,###.00" //number format. In this example: thousands separator with padding of 2 zeros
var directionColor = "blue='255'"; //direction color: red, green, blue, cyan, magenta, yellow, black. You can also use RGB or CYMK combinations.
var distanceColor = "black='255'"; //distance color: red, green, blue, cyan, magenta, yellow, black. You can also use RGB or CYMK combinations.
var radiusColor = "blue='255'"; //radius color: red, green, blue, cyan, magenta, yellow, black. You can also use RGB or CYMK combinations.
var curveParamColor = "black='255'"; //curve parameter color: red, green, blue, cyan, magenta, yellow, black. You can also use RGB or CYMK combinations.
var partialCOGOColor = "magenta='255'"; //partial COGO color: red, green, blue, cyan, magenta, yellow, black. You can also use RGB or CYMK combinations.
var invalidCOGOColor = "red='255'"; //invalid COGO color: red, green, blue, cyan, magenta, yellow, black. You can also use RGB or CYMK combinations.
var fontNameSize = "<FNT name = 'Arial' size = '10'>"; //font type and size
// VARIABLES
var cogo_direction = $feature.Direction;
var cogo_distance = $feature.Distance;
var cogo_radius = $feature.Radius;
var cogo_arclength = $feature.Arclength;
var cogo_radius2 = $feature.Radius2
var binaryDictionary; //binary dictionary to check COGO combinations
var checksum = 0; //initialize checksum
var validValuesArray; //array of valid values for COGO combinations
var partialValuesArray; //array of partial values for COGO
var degrees;
var minutes;
var seconds;
var DMS;
var directionStr = ""; //direction string using for label
var distanceStr = ""; //distance string using for label
var radiusStr = ""; //radius string using for label
var radius2Str = ""; //radius2 string using for labeling spiral curves
var curveStr = ""; //curve parameter string using for label
var angleRad; //curve angle in radians
var COGOValidity; //COGO combinations validity. can be valid, partial or invalid.
if (IsEmpty(cogo_direction) && IsEmpty(cogo_distance) && IsEmpty(cogo_radius) && IsEmpty(cogo_radius2) && IsEmpty(cogo_arclength)){
return ""
function NorthAzimuth2Quadbearing(azimuth){
return ConvertDirection(azimuth, {directionType:'North', angleType: 'Degrees'}, {directionType:'Quadrant', angleType: 'DMS', outputType: 'text', format: 'pd[°]mm[\']ss["]b'})
function DMS_North(azimuth){
return ConvertDirection(azimuth, {directionType:'North', angleType: 'Degrees'}, {directionType:'North', angleType: 'DMS', outputType: 'text', format: 'd[°]mm[\']ss["]'})
function DMS_South(azimuth){
return ConvertDirection(azimuth, {directionType:'North', angleType: 'Degrees'}, {directionType:'South', angleType: 'DMS', outputType: 'text', format: 'd[°]mm[\']ss["]'})
function IsValidCOGO(cogo_direction, cogo_distance, cogo_radius, cogo_arclength, cogo_radius2) {
binaryDictionary= Dictionary('dir', 1, 'dist',2, 'rad',4, 'arc',8, 'rad2',16)
if (!IsEmpty(cogo_direction)) {checksum+=binaryDictionary.dir}
if (!IsEmpty(cogo_distance)) {checksum+=binaryDictionary.dist}
if (!IsEmpty(cogo_radius)) {checksum+=binaryDictionary.rad}
if (!IsEmpty(cogo_arclength)) {checksum+=binaryDictionary.arc}
if (!IsEmpty(cogo_radius2)) {checksum+=binaryDictionary.rad2}
validValuesArray=[0,3,13,29]; //array of valid combinations: '0' for nothing, ... '13' for direction & radius & arclength ...
partialValuesArray=[1,2,4,5,8,9,12,16,17,20,21,24,25,27,28]; //array of partial combinations: '1' for only direction, '2' for only distance, '4' for only radius...
//Invalid Values = [6,7,10,11,14,15,18,19,22,23,26,30,31]
if (IndexOf(validValuesArray,checksum)>-1) { // a negative value is returned if checksum value is not in the a valid combination array
return "valid";
if (IndexOf(partialValuesArray,checksum)>-1){
return "partial";
return "invalid";
COGOValidity = IsValidCOGO(cogo_direction, cogo_distance, cogo_radius, cogo_arclength, cogo_radius2);
if ( COGOValidity == "invalid") { //if invalid COGO return error string
return "<BOL><CLR " + invalidCOGOColor + ">" + fontNameSize + ErrorString + "</FNT></CLR></BOL>";
if (COGOValidity == "partial") { //if a partial COGO change colors
distanceColor = partialCOGOColor;
directionColor = partialCOGOColor;
radiusColor = partialCOGOColor;
curveParamColor = partialCOGOColor;
// Direction string
if (ShowDirection) {
if (IsEmpty(cogo_direction)==false) {
if (DirectionType == 1) { //using quadrant bearing format
directionStr = NorthAzimuth2Quadbearing(cogo_direction);
else if (DirectionType == 2) { //using north azimuth format
directionStr = DMS_North(cogo_direction);
else if (DirectionType == 3) { //using south azimuth format
directionStr = DMS_South(cogo_direction);
// Distance string
if (ShowDistance) {
if (IsEmpty(cogo_distance)==false) {
distanceStr = text(round(cogo_distance,DistUnitRounding), NumberFormat);
//Radius String
if (ShowRadius) {
if (!IsEmpty(cogo_radius)) { //it can be a curve or a spiral
if (IsEmpty(cogo_radius2)) { //if radius2 is empty this is a curve
radiusStr = RadiusAbbr + " " + text(round(cogo_radius, DistUnitRounding), NumberFormat);
else { // it is a spiral
radiusStr = RadiusAbbr + " " + text(round(cogo_radius, DistUnitRounding),NumberFormat);
radius2Str = Radius2Abbr + " " + text(round(cogo_radius2, DistUnitRounding),NumberFormat);
if (cogo_radius == 0) { //substitute to infinity sign
radiusStr = RadiusAbbr + " ∞ ";
if (cogo_radius2 == 0) { //substitute to infinity sign
radius2Str = Radius2Abbr + " ∞ ";
// Curve Parameter
if (ShowCurveParameter) {
if (CurveParameter == 'ArcLength') {
curveStr = text(round(cogo_arclength, DistUnitRounding), NumberFormat); //return Arc length
angleRad = cogo_arclength/(abs(cogo_radius)) //calculate angle in radians
if (CurveParameter == 'Angle') {
curveStr = DMS_North(angleRad * 180 / pi); // convert radian to degrees and show as DMS
if (CurveParameter == 'Chord') {
curveStr = text(round((2 * abs(cogo_radius) * Sin(angleRad/2)),DistUnitRounding), NumberFormat); //calculate chord length
//Determine type of curve displayed
var CurveTypePrefix = ""
if (!IsEmpty(curveStr)){
if (CurveParameter == 'ArcLength'){
CurveTypePrefix = ArclengthAbrr
else if (CurveParameter == 'Angle'){
CurveTypePrefix = AngleAbbr
else if (CurveParameter == 'Chord'){
CurveTypePrefix = ChordAbbr
var isStraightLine = IsEmpty(radiusStr) && IsEmpty(radius2Str) && IsEmpty(curveStr)
// Assemble label string
//Straight lines
if (isStraightLine){
if (!IsEmpty(directionStr) && !IsEmpty(distanceStr)){ //If Direction and Distance are both NOT Empty
return fontNameSize + "<CLR " + directionColor + ">" + directionStr + "</CLR>" + "\n" +
"<CLR " + distanceColor + ">" + distanceStr + "</CLR></FNT>";
else if (IsEmpty(directionStr)){ //If Direction is empty
return fontNameSize + "<CLR " + distanceColor + ">" +
else{ //If Distance is empty
return fontNameSize + "<CLR " + directionColor + ">" + directionStr + "</CLR></FNT>";
//Curves
//If one or both radii and the curve string are NOT empty show the full curve
if ((!IsEmpty(radiusStr) || !IsEmpty(radius2Str)) && !IsEmpty(curveStr)){
return fontNameSize + "<CLR " + radiusColor + ">" + radiusStr + "</CLR>" + " " +
"<CLR " + radiusColor + ">" + radius2Str + "</CLR>" + "\n" +
"<CLR " + curveParamColor + ">" + CurveTypePrefix + ' ' +
curveStr + "</CLR></FNT>";
//If the curve is empty
else if (IsEmpty(curveStr)){
"<CLR " + radiusColor + ">" + radius2Str + "</CLR></FNT>"
//If both radius are empty
else{
return fontNameSize + "<CLR " + curveParamColor + ">" + CurveTypePrefix + ' ' +
ArcPro:
Web Map:
KenBuja
MVP Esteemed Contributor
Labels in web maps aren't able to render the formatting tags with Arcade. I think the only solution would be to set up a label class for each of the different colors used in your labels.
KenBuja
ThomasGoodridge
