Hello Everyone,
I have a need to connect my Arcgis Online data to the SQL database. Could you please suggest what is the easiest way to do it?
Thank you,
Yulia
Hi Yulia,
You will need ArcGIS Server. You will then be able to publish data from your SQL database as ArcGIS Server services. These services can then be used within ArcGIS Online.
Can't it be done just by having a REST API for the data from SQL Server?
Hi. Did you get anywhere with this? We want to pull new records from a hosted featurelayer to a flat sql table.
Scott Foster you can use ArcGIS Pro's Feature Class to Feature Class tool to write the AGOL Survey123 feature service to a geodatabase feature class.
I also need to pull data from a feature service into a sql database. I already pull data from the database for publishing, but now I need to pull survvey123 data into the database.
Thoughts?
Signed in members can post, follow updates, and more. New here? Register a free account.
