Configuring the Web Adaptor on Portal
3509
03-24-2014 06:31 AM
BrendanDwyer
We are working with Portal and Server 10.2.1, on separate virutal machines and we want to federate them.  Both machines have names like "ddtxlivtpa01".  So we have DNS aliases for both, for example "arcserver" and "arcportal."
My question is: when we configure the web adaptor on each machine, which name should we use, the machine name or the alias?
Also, when configuring the portal, which names should I use when I federate to the server?  It asks for a service url and an administration url.  For the service url the example is "https://webadaptor.domain.com/arcgis" and the admin url example is "https://gisserver.domain.com:6443/arcgis".  Does the difference mean that you're supposed to use a machine name for one and an alias for the other?
Thanks.
BrendanDwyer
Worked this out myself through trial an error.  On the web adaptor, we used the dns alias.
When federating, we used the web adaptor url for the service url, and the machine name for the admin url.
BrendanDwyer
