Configure pop-up for individual features?
4893
03-08-2012 11:45 AM
by Anonymous User
Not applicable
I've been experimenting with editing pop-up boxes and am having an issue with images. In my point shapefile in ArcGIS, I have created a field called "Photo1" and a field named "URL". Each point will have a unique picture associated with it, which is linked within the attribute table. For example, in the attribute table (under Photo1) for Point A, I have a web address pointed to Picture A that shows what Point A is, then a web address to Picture B for Point B, and so on. I also have a website link for each point in the "URL" field, which will create a hyperlink in the pop-up (this is working fine).
However, I'm having trouble understanding how the image in a pop-up works in ArcGIS Online. Whether in map view or Explorer Online, I can configure pop-ups and go to Pop-Up Media to insert images, charts, etc. that have a web address. How do I tie each unique image to a unique point so when a user clicks Point A, Picture A shows up in that pop-up, and when they click on Point B, Picture B shows up in that pop-up, and so on?
From what I have done so far, the Pop-Up Media affects EVERY pop-up for all points. So everytime I click on a point in the webmap, all the images show up as a "slideshow" type thing within the pop-up. How do I separate these items out for each pop-up? Can I do this within the web map or is this something I need to do from within GIS Desktop?
Right now each image's web link within the attribute table shows up as a "more info" hyperlink in the pop-up box, which when clicked loads a full-size Picture A or Picture B. But I want those images to come up within the pop-up, and when I try to do that, all the images show up.
Am I doing this all wrong?
MikeMinami
Esri Notable Contributor
When you add an image as the popup media, use the field name surrounded by curly braces to populate the URL property, like this.
{Photo1}
There is also a "+" button next to the input field that will list all of your fields and insert it. You can also have multiple fields that define the URL. For example, suppose I have one field that has an image name, "some.png" and another field that contains the base url to the image, "http://mserver.com/images/". You can concatenate the two fields like this.
{BaseURL}{ImageName}
Mike
by Anonymous User
Not applicable
{Photo1}
Mike
Thanks Mike. I'll give that a try and see if it does what I want.
Update: That's doing what I need, thanks again Mike. The images took about 10 seconds to load in each popup, but I shrunk them down and re-uploaded to our webserver and the pop-ups load much faster now.
CarolineVallieres
Hello, I managed to concatenate the fields however, I get an X instead of the image. Is there a way to fix this?
Thanks!
Caroline
MikeMinami
Yes, if you want unique images for each feature, you need something on the feature that determines its uniqueness...adding a field, or using an existing field is the only way.
Mike
