Conditional Visibility w/ Arcade in AGOL – Show/hide pop up field based on attribute value in another field
4502
6
01-18-2022 11:39 AM
RyanR
Hello. I am new to Arcade and my current task is to hide or show an attribute field and value if another field in the same table meets a condition. I am wondering if I can create an expression to do so. I have seen some examples in Field Maps, but not in AGOL or Portal.
For starters the layer I am using in my map is a hosted feature layer view with configured domain values.
Example. If the field ProblemType =’s the views domain value of ‘Dead animal’ then show Location on Road field and its value in pop up. If it does not = ‘Dead animal’ then hide.
A couple thoughts.  I know I can create an expression to hide or show the field I want the condition for. Easy right.
IIF(ProbType == "Dead Animal", "inline", "None")
But how do I add another field, the one I want to actually hide/show ($feature.locroad) into this statement or another type of logic to accomplish my task?
RyanR
Good point and thanks. A fresh head this am, some good coffee, and a dive into the documentation provided me with what I needed for success. Simple once I understood proper syntax of function.
var deadanimal = $feature.probtype == "DEAD ANIMAL";
var roadloc = $feature.locroad;
IIf(deadanimal, roadloc, "None");
 Now to see if this will work in Citizen Problem Reporters built in from, which I believe behaves based on pop up configuration.
jcarlson
Can you elaborate a bit? The expression you've shared could be used anywhere in your popup text to show/hide not just a field value, but entire HTML elements.
For instance, this HTML in your popup would display the locroad field based on an expression, but the expression itself could evaluate against anything.
<div style="display:{expression/expr0}">{locroad}</div>
Can you share the full expression you've got so far, or the popup's source HTML code?
- Josh Carlson
Kendall County GIS
RyanR
Thanks for replying Josh and good question. I have not really come up with an expression at this time other than what I have already stated. In the grand scheme of things I am trying to modify some existing HTML pop up code that is included in Esri Citizen Problem Reporter app:
{category} problem reported on {CreationDate}.<br /><br />
<b>Details:</b> {details}<br /><br />
<b>Status:</b><br />
<table style="border-collapse: separate; border-spacing: 2px 4px; width: 100%; table-layout: fixed; margin: 0px -2px; max-width: 350px;">
<tbody><tr height="16">
<td style="{expression/expr0}; text-align: center; width: 25%"></td>
<td style="{expression/expr1}; text-align: center; width: 25%"></td>
<td style="{expression/expr2}; text-align: center; width: 25%"></td>
<td style="{expression/expr3}; text-align: center; width: 25%"></td>
</tr>
<tr height="24" style="text-align: center;">
<td style="text-align: center; width: 25%; font-weight: normal; padding-left: 0px; word- wrap: break-word;">Submitted</td>
<td style="text-align: center; width: 25%; font-weight: normal; padding-left: 0px; word- wrap: break-word;">Received</td>
<td style="text-align: center; width: 25%; font-weight: normal; padding-left: 0px; word- wrap: break-word;">In Progress</td>
<td style="text-align: center; width: 25%; font-weight: normal; padding-left: 0px; word- wrap: break-word;">Completed</td>
</tr>
</tbody></table>
<table style=" border-collapse: separate; border-spacing: 0px 0px; width: 100%; table-layout: fixed; margin: 0px -1px;">
<tbody><tr>
<td style="display:{expression/expr4}; text-align: left; width: 100%">
<b><br />Resolved On:</b> {resolutiondt}<br /><br />
<b>Resolution:</b> {resolution}
</td>
</tr></tbody>
</table>
So I would like to add the locroad field and formatting preferably above the Resolved On field and only show it when it meets this expression:
When I added your suggested HTML modified with my expression:
<div style="display:{expression/expr5}"><b>Location on Road:</b> {locroad}</div>
It adds the locroad field, but is not hiding it based on the conditional expression. For example it is showing it for another probtype = Graffiti painted on a county asset. This is a condition when I would like to hide it:
This is the correct behavior for Dead animal and the only case when I want Location on Road: <domain value> to show in the pop up. For any other domain value I don't want to show it.
Thanks!
RyanR
Sure thing, although it gets a bit complex. I think what I am trying to achieve may be simple, but the current HTML code is as follows and is included with the esri Citizen Problem Reporter application which I am trying to customize.
  </tr>
  </tr>
</tbody></table>
  <tbody><tr>
	  <b>Resolution:</b> {resolution}<br /><br />
	</td>
  </tr></tbody>
</table>
 I would like to add the field locroad and formatting. I only want locroad to show if the probtype == "Dead animal" If not, I do not want locroad to show.
I created an expression DeadAnimal[expression/expr5) for the condition:
$feature.probtype == "Dead animal";
 Then I simply modified and added your HTML idea:
<div style="display:{expression/expr5}">{locroad}</div>
 While this added the locroad to the pop up, it is not evaluating the expression showing the locroad field and formatting for a probtype that is not "Dead animal"In this case I do not want the locroad field to show because it is a different porbtype (Graffiti painted on county asset)
I hope this provides some clarification.
KenBuja
You have to use an expression that returns values that will show or hide the div. Just returning True or False won't suffice.
IIF($feature.probtype == "Dead animal"), "inline", "None")
RyanR
RhondaE
Hi, could this be done with a *group* of fields? Also in the context of a Field Maps. I'm struggling with how to include the code for the group since it doesn't show up as a 'Globals' option like the individual fields. Thanks!
Solved:
Hi all, this has been solved by a coworker of mine. Using Arcade syntax preview, the script applied to the *group* of fields was: DomainName($feature, "ARTIFACTS") == "YES"
This results in the group being hidden in the Field Maps form unless YES is selected.
