Conditional Visibility of Related Tables in Popup
667
07-17-2023 02:58 AM
Labels (3)
FieldMapper
Does anyone know if it's possible to set up conditional visibility for related tables in a popup?
So for a polygon, there are different surveys depending on habitat type. A surveyor will conduct a grassland survey when the polygon is grassland, and a woodland survey if the habitat is woodland.
There are therefore three things: the poylgon feature layer, the grassland survey related layer, and the woodland survey related layer.
If a polygon is surveyed as grassland, then the woodland survey is not applicable. Can I hide surveys where there are no records found in the related table for a point? At the moment, it says no records were fine. This is okay for the example listed, but I have about 30 related tables and it's a bit messy!
If not, is it possible to configure text in the popup to show related records using arcade?
