Combine geopoints from two different surveys
215
12-12-2025 12:53 PM
EdwardKairiss
Hi - I have several surveys that are being performed in the same town. Each collects geopoints, and I'm able to build separate dashboards for each. I'd like to make a summary dashboard with a map that shows all of the points from each of the surveys in the town. I can't figure out how to combine the data sets to do that. Thanks for any help.
JamesPoeschel
I guess there are many ways to go about this. You could put all the survey point layers into one web map, put that webmap into a dashboard, and configure from there. You can put them all into a group with exclusive visibility if you want the user to see just the points and statistics of one survey at a time. Or if you wanted to have it all in one layer you can just load the survey points into PRO and merge, and publish the layer and use that.
